Late to this thread, but whatever...
I've been curious as to how 4 load cells, each with +v/-ve strain gauges in them could produce an overall differential output that is proportional to the sum of the 4 individual loads on them.
Answer - they don't, but it is pretty close.
Here's some analysis:
#!/usr/bin/python3
Analysis for a 4 load cells (2 strain gauges each) wired to give a single differential output.
https://www.eevblog.com/forum/reviews/large-cheap-weight-digital-scale-options/
def deltav(V, R, r0, r1, r2, r3):
"""return the differential output voltage for the 4x load cell"""
i0 = V / (4.0 * R + r0 - r3)
i1 = V / (4.0 * R - r0 + r3)
va = i0 * (2.0 * R - r1 - r3)
vb = i1 * (2.0 * R + r2 + r3)
return va - vb
def main():
Ve = 5.0
Rn = 1000.0
x = deltav(Ve, Rn, 1, 1, 1, 1)
print(x)
x = deltav(Ve, Rn, 0, 0, 0, 4)
print(x)
x = deltav(Ve, Rn, 0, 0, 2, 2)
print(x)
x = deltav(Ve, Rn, 0, 2, 2, 0)
print(x)
x = deltav(Ve, Rn, 0, 1, 3, 0)
print(x)
x = deltav(Ve, Rn, 0, 0, 3, 1)
print(x)
x = deltav(Ve, Rn, 1, 0, 0, 3)
print(x)
main()
jasonh@eccles:~/work/bmon/analysis$ ./loadcell.py
-0.004999999999999893
-0.005000005000005192
-0.0049987512496882935
-0.004999062812441224
-0.005000001250000441
So yes - there will be some differences depending on how the load is distributed to the load cells, but it's probably not enough to care about.
