Author Topic: New Metcal CV-5210 - The iron tells you when the connection is good  (Read 12960 times)
Offline ZuccaTopic starter
  • EE meid in Itali
http://www.okinternational.com/CV-5210-Connection-Validation-Soldering-Station
 :o
if it would have been a Kickstarter I would call it out as a scam, but it's the new Metcal puppy.
We all now Metcal is not a garage company.
To me they are trying to sell something better than the "SmartHeat", problem is there is nothing better than Metcal SmartHeat.
BTW the new OLED TFT color display touch screen looks funky. It seems if you want to sell a product in the 2018 you need to have a color display.
Anyone tried it out? comments?
« Last Edit: July 23, 2018, 02:58:00 pm by zucca »
Offline glarsson
Re: New Metcal CV-5210 - The iron tells you when the connection is good
« Reply #1 on: July 23, 2018, 10:19:50 am »
Yes, they are too small for that. Real garage companies are big, e.g. Apple and HP.
  • EE meid in Itali
« Reply #2 on: July 23, 2018, 10:20:20 am »
There is also a SW:
http://www.okinternational.com/metcal/english/globalnavigation/resources/software-download
Improve your solder process traceability and create a performance baseline using CV's intelligent cartridges plus CV-5000 Monitor software. Using our Connection Validation patented technology, CV Monitor software allows you to capture solder process information over time for each joint when attached to the communication port. You'll get:
• Intermetallic Compound Formation (IMC Formation)*
• Power demand
• Tip temperature
• Solder time
wow, they are making a nice jump.
« Reply #3 on: July 23, 2018, 10:23:52 am »
Well I presume its not just not marketing hype but how can it tell that the connection is good, I can't see, maybe it just acts like a timer to keep the heat there long enough to have made a good connection?
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #4 on: July 23, 2018, 10:47:25 am »
I think it also measures delivered power - it has a database of characteristics for each tip type.
Day Job: Mostly LEDs
Offline VK5RC
« Reply #5 on: July 23, 2018, 10:49:11 am »
I would punt it might look at impedance as the tip has 14MHz or so quite close by and if both sides of the solder joint are well connected the impedance would decrease I guess.  :blah:
Offline GeorgeOfTheJungle
  • Country: tr
« Reply #6 on: July 23, 2018, 10:50:48 am »
It's a soddering system!
The following users thanked this post: artag
« Reply #7 on: July 23, 2018, 12:01:24 pm »
I would need some sort of evidence of how the system actually worked before I could believe that its not just some marketing ploy to get extra sales by "making" other systems seem obsolete and get the blind sheep flocking to the dealers to get the latest must have gadget
« Last Edit: July 23, 2018, 12:32:28 pm by Specmaster »
  • EE meid in Itali
« Reply #8 on: July 23, 2018, 12:19:55 pm »
Let's think.. so a delivered energy counter?
1) Take the iron out the stand, magnetic stand-by function triggers a counter reset.
2) iron going to temperature --> counter should stay zero since power is delivered but it has nothing to do with soldering
3) Iron touch metal or melt solder ---> counter going up
Not sure when they turn the green LED on, if it is a simple counter reaching a threshold... how can they know I am touching a ground plane metal or I am melting solder? In both case the iron is dropping energy somewhere...
The point 2) can be managed knowing the typical profile of each tip.
Maybe they sense the drop in energy delivered when the joint reach the temperature tip --> I vote for this one.
EDIT: I was wrong, it's the IMC formation.
That said, who needs that? You can't desing an idiot proof iron.
Oh I know, those quality eng. department will push to have a reproducible and documented hand soldering process... maybe it's smarter to save the money and invest in checking the final board?
« Last Edit: July 23, 2018, 01:12:53 pm by zucca »
Offline GreyWoolfe
  • NW0LF
« Reply #9 on: July 23, 2018, 12:26:12 pm »
Are they trying to tell us that our eyes are no longer good enough to tell a good solder joint.  And to think, it is only $799 on Mouser, not counting tip cost.  If I am too blind to see the joint in the first place and then miss a bad joint upon inspection, maybe it is time to sell my soldering equipment.
« Reply #10 on: July 23, 2018, 12:31:31 pm »
No matter what the price is there will be enough take up for the exercise to be worthwhile as there will be people who have more money then sense.
  • EE meid in Itali
« Reply #11 on: July 23, 2018, 01:09:51 pm »
LED green is triggered when the right amount of IMC is formed according to some black magic algorithm.
I think yes, they are telling us we can't see the IMC.
BTW accoring to the video on the top, I don't like the amount of time the tip stays on the joint. Everybody told me to be as quick as possible with the iron on the board.
I am personally starting to smell  :bullshit: BS.
« Last Edit: July 23, 2018, 02:09:21 pm by zucca »
  • Country: tr
« Reply #12 on: July 23, 2018, 01:19:40 pm »
You can see it failing at 06m05s  >:D
« Last Edit: July 24, 2018, 02:33:42 pm by GeorgeOfTheJungle »
  • EE meid in Itali
« Reply #13 on: July 23, 2018, 01:26:22 pm »
 :palm:
Lord have mercy I am a sinner, here the frame at 06m05s:
GeorgeOfTheJungle thank you so much
 :-DD
EDIT: On a second thought, I think the equipment is working OK.
The problem was/is and will be the idiot holding the iron, as it was in the beginning, is now, and ever shall be, world without end. AMEN.
« Last Edit: July 23, 2018, 02:55:37 pm by zucca »
« Reply #14 on: July 23, 2018, 02:27:38 pm »
Too many varibles can effect the IMC, cleanliness, size of pad, ie ground plane etc. BS is in the air I think.
Offline radar_macgyver
« Reply #15 on: July 23, 2018, 02:44:52 pm »
The cynic in me thinks the real reason is the 'smarts' in the tip will make it incompatible with Thermaltronics tips. DRM for soldering irons?  :scared:
  • EE meid in Itali
« Reply #16 on: July 23, 2018, 02:54:34 pm »
I don't think so, if the Thermaltronics  tip works on the MX-5xxx system it work also on the CV-5210.
The CV is backward compatible with the MX-5xxx.
« Reply #17 on: July 23, 2018, 04:04:37 pm »
Remember guys... MetCal isn't selling to repair shops and EEs.
They're selling to manufacturers who need to turn out product by the hundreds of thousands, soldered by assembly line muppets. Also, you have specialty markets like medical and military/defense contracting, where quality of solder joints is paramount and ZERO  crib death/DOA is a REQUIREMENT; to the point where they have 100% test/inspection factor, and in some cases, part of the assembly process is x-raying of the solder joints to check for voids and improper wetting of parent/component metals. This would be another layer of validation specifically for the hand-soldered portions of that production.
This is NOT a product for the average electronics hobbyist or repair tech.
moo?
The following users thanked this post: mairo
Offline tooki
« Reply #18 on: July 23, 2018, 04:10:07 pm »
They put in a touchscreen, but kept a piezo speaker that bleats out the same sound as a smoke detector warning of a low battery? I’d go fucking berserk with that annoying high pitched beep all day long. They couldn’t have given it a pleasant sound???
  • EE meid in Itali
« Reply #19 on: July 23, 2018, 06:45:48 pm »
Fair enough, definitely and iron station not for us. I agree.
On top of that, they should have design a battery Metcal iron. Ops my next project.
« Reply #20 on: July 23, 2018, 06:59:15 pm »
moo?
What happened to solder baths and flow soldering then?
« Reply #21 on: July 23, 2018, 07:06:19 pm »
Not a great idea as the RF PSU is rather inefficient. Just buy a TS100.
Offline nanofrog
« Reply #22 on: July 23, 2018, 08:34:49 pm »
...[snip]...problem is there is nothing better than Metcal SmartHeat.
More personal opinion these days than fact, as other top tier manufacturers have at least caught up, if not surpassed it. Remember, it's 35 y/o tech these days.
Curie point still has a strong place in manufacturing though as operators can't screw with temps and foul up the process control. Nothing to bypass or circumvent as could be done with stations that rely on lock-out for this purpose.
Offline tooki
« Reply #23 on: July 23, 2018, 08:52:21 pm »
moo?
Maybe for PCBs, but a lot of the military/aerospace stuff is also things like connectors. (A lot is crimped, of course, but a lot is soldered.)
Offline Jamieson
« Reply #24 on: July 23, 2018, 09:19:02 pm »
If so, it wouldn't be the first time Metcal tried to discourage use of Thermaltronics cartridges. A few years ago the Metcal MX-500 firmware was updated to check if a Thermaltronics M series cart was installed in the handle. Apparently Thermaltronics carts heat up a few seconds faster than Metcal carts. If the Thermaltronics tip was detected the power unit would display an error message and shutdown. Thermaltronics described this issue and a workaround in their June 2014 newsletter.
