Author Topic: New Hantek gears released  (Read 24885 times)
Offline tinheadTopic starter
Re: New Hantek gears released
« Reply #25 on: December 31, 2013, 01:55:53 am »
i can only guess ... one is sure, the 4ch model with AWG is the "all you can get" in that new black/gray case. So probably the photoshop genius while "working on DSO5074" (later renamed to MSO5074) decided to make some knobs smaller and remove such useless things like "single print" button as there was no space  :rant:
Offline echen1024
  • 15 yo Future EE
« Reply #26 on: December 31, 2013, 02:10:47 am »
And what the hell is up with that F7 button?
I'm not saying we should kill all stupid people. I'm just saying that we should remove all product safety labels and let natural selection do its work.
https://www.youtube.com/user/echen1024
« Reply #27 on: December 31, 2013, 02:17:59 am »
on the new models no idea, but on DSO5xxx models that a function knob to switch on/off dual window mode (which is nice and useful). On MSO5000 it is bit crazy multiknob, so one can select between single/dual window and enable/disable MSO (which is crap and useles). EDIT: no, not useless, but simply double crap. I hate this that much, that i hacked the firmware and moved the MSO functionality to help button (help moved to an useless sys status menu). Now i can enable/disable such major fun ction with dedicated function buttons, and not cycle with one button . Why i think that this is crap -> imagine following situation: you measured with one channel something, then you wish to see that stopped waveform in dual window, e.g. set some markers and search through the waveform ... so you push F7, everything fine, you doing some work, then you wish back to single window - booom , the stupid MSO is enabling second channel and your work is gone, now you push again and MSO is off, but still data captured before is gone. This is double crap.
« Last Edit: December 31, 2013, 02:26:03 am by tinhead »
Offline echen1024
  • 15 yo Future EE
« Reply #28 on: December 31, 2013, 03:16:25 am »
And the misaligned BNCs. Oh god my eyes are just about ready to roll out of their sockets.
Offline Smokey
  • Not An Expert
« Reply #29 on: January 28, 2016, 11:58:38 pm »
Wow.  Talk about a long time to market.  I was going to start a new thread but I figured I've revive this one.
Looks like they are finally releasing their DSO8000E and DSO1000E handheld scopes....
http://www.hantek.com/en/ProductDetail_1_159.html
http://www.hantek.com/en/ProductDetail_1_158.html
DSO8000E Specs:
    Six in one: Oscilloscope/Recorder/DMM/ Spectrum Analyzer/Frequency Counter/Arbitrary Waveform generator.
    IP-51 rated for dust, drip and shake proof to withstand harsh environments.
    Large fuse confirms to European Safety Standard.
    Battery indicator with easy-changed connect points. Selectable 18650 battery box for matching 18650 battery by yourself.
    Anti-theft lock hole, tripod fixed hole, hang rope, FLASH light that can be used in darkness.
    Replaceable BNC safety joints, and additional one set of joints.
    High bandwidth 70MHz-200MHz Oscilloscope, 1GSa/s sample rate, 2M Memory depth.
    25Mz Arb. Waveform Generator, 200 Mesa/s DDS, 12 bit vertical resolution, easy for simulating transducer
    6000 Counts DMM, AC/DC voltage, AC/DC current, resistance, break, capacitance, and diode function.
    FFT spectral analysis; Waveform Math: add, subtract, multiply and divide; X-Y mode; more than 20 automatic measurements; PASS/FAIL Check function, apply to engineering application.
    Abundant trigger function, double timebase sampling, easy to observe two waveforms in different frequency.
    Record and replay of more than 1000 waveforms.
    Large 5.6 inch TFT Color LCD Display; High Resolution(640*480)
    USB Host/Device 2.0 full-speed interface; support removable disk;  WIFI/LAN Option, easy to control by PC or long-distance.
    Waveform data can be output in WORD?EXCEL, BMP, JPG as time and voltage.
Offline Smokey
  • Not An Expert
« Reply #30 on: January 29, 2016, 12:09:53 am »
Offline Smokey
  • Not An Expert
« Reply #31 on: October 03, 2017, 03:38:00 am »
Checking in on these things to see if the price had dropped at all...
Ebay DSO8072E = $563.00 USD
Are the prices significantly cheaper if you are actually in China, or is it about the same?
