Hello, I’m very excited to reveal a new design for a dispenser that I’ve been working on for the last year. No need for compressed air, super easy to start using, can be hooked up to a 3D printer and it can also double as a vacuum pick up tool!
Here’s a video that I made, make sure to watch to the end: (sorry if the editing is bad, there’s a lot to cover)
If I had to say what the biggest advantage of this dispenser is, I would say convenience/ease of use, what's the point of getting something if you never touch it after 2 or 3 tries because it's a pain to actually use it? quick refills, small size, USB powered, simple UI, syringe design, all add up to remove the hassle of setting up and using the machine.
I actually have some experience in this field, originally I designed the system for work back in 2014, to be used in an industrial environment (for adhesives), as you know time is critical and any new operator has to be able to pick it up and start using it right away. You actually have to assume people DON’T want to use it in the first place, if you had to sit there dispensing for 3-4 hours every day you’d also be annoyed by even the smallest problems.
Anyway, after many months of getting it "consumer" ready I've finally finished it, took much longer than I thought but I'm very happy with it. I’ll start selling it on ebay or tindie or something similar (other ideas?) in the next couple of weeks. This is a great little tool if you’re looking to get into SMD prototyping, or if you do it already and just want to make your life easier.
It will include the following:
-Controller and stepper motor.
-2 empty syringes with caps and pistons, there's clear or amber color for UV sensitive adhesives.
-10 luer tips, I can recommend a couple depending on your application.
I will also have external switches ready to use: Pedal, finger switch and proximity sensor, as shown in the video. These are optional and you can always make your own of course.
Here’s some comparisons:
VS stenciling:-Faster setup and cleaning time, plus you can use the vacuum pick up mode to place the components. When you consider everything it’s probably faster for one-off prototypes of small and medium sized boards.
-Much less messy and wasteful.
-Stencils add extra cost and/or time to each PCB order.
By the way even if you already use stencils and are very happy with them you can still use this dispenser to apply exactly the right amount of paste for each squeegee pass or even just for the pick up mode, of course there’s already vacuum picking machines from china, but they’re big, cumbersome, noisy and not that cheap (the good ones at least).
VS a compressed air dispenser:-Much smaller footprint, just 9x7cm saves space in your bench.
-No compressor.
-Pedal or any other external switch is optional so you don’t have to run extra wires on the floor and table if you don’t want to.
-Much more flexible triggering options.
-LCD with numeric control for a better user experience, instead of pressure gages and dials.
- Maximum dispensing speed is lower but in practical terms it's not bad at all, too fast is not desirable either since you'll quickly loose consistency in drop size.
-Dry pastes with play doh-like consistency can't be dispensed or it gets difficult, if you really want to reduce the viscosity there's a couple of ways to do it, but you should be using quality paste regardless of dispensing method.
-Internal memory stores settings for up to 15 different types of fluids.
-You can hack it! If you have a very weird application you can connect to the ICSP header and reprogram the micro with custom firmware but it’s so flexible that it’s not even necessary, but yes it’s possible.
-Has vacuum pick up mode! no need to buy a separate machine, yet more money and space saved in the bench.
If you have questions, suggestions, want some tips, know the history behind it or anything please ask, but most importantly tell me if you’d be interested in buying one of these. The size of my first batch will greatly determine the BOM cost and therefore final sale price, if a lot of people show interest I can commit to buy a larger volume of parts, I can say for certain that it's going to be cheaper than buying a dispenser plus a vacuum pickup from ebay.
Cheers, Dan
