I've been looking at getting a T3B but Im seriously considering getting this instead. The only thing thats stopping me is that it doesn't support T115 handles. I will be using the station for mostly Nintendo Switch Mods. Are the T210 tips much bigger than the T115s?
I got the T420 (not the D). Just so I could use the T115, I already had the T3A with the T245. (but now driving both hand pieces with the T420). I've actually been very happy with that iron and have almost never run into a situation in which it is difficult to solder something.
But as you hint at, I've done some work on SMD circuits where the hand piece is just too bulky and sometimes even the heater tip was just too large.
I got the T115, got a NT115 JBC handle (did the same for T245, I want the "authentic JBC" experience as far as possible) and then a couple of fine JBC tips.
For example this 0.1mm tip
![New Aixun T320 - Any opinions on it? (with inside pics) 1976994-0](https://www.eevblog.com/forum/index.php?action=dlattach;topic=398616.0;attach=1976997;image)
It is literally the size of a needle you'd use in sewing (just as sharp too). I've now tested it on a couple of very small components and although it is incredible fine and pointy so I can get in there no problem, it does struggle with heat a bit. I probably need more experience with it.
I also got a chisel tip and it does better but it is still a very different experience from T245:
![New Aixun T320 - Any opinions on it? (with inside pics) 1976988-1](https://www.eevblog.com/forum/index.php?action=dlattach;topic=398616.0;attach=1976991;image)
I've not used T210 at all, but I'm still happy I went with the T115 instead because I don't really see the point. I was already able to do practically everything with T245, sometimes it was a bit more annoying to do it, but I got it done. So to me the next smaller iron really had to tackle those VERY hard to do jobs and I couldn't convince myself the T210 is going to do that as well as the T115.
The T115 overall is actually very small and pictures will not give you an accurate representation.
I saw it on videos and still didn't comprehend fully until I held one.
It is fair to say I'll be using T245 95% of the time unless the work calls for very tiny work.
I can't justify spending a bunch of money on T210 to work with that but I suspect I'd still be frustrated by the lack of power compared to what I've gotten accustomed to with the T245 (absolute beast with a chisel tip).
