Display and keyboard PCB:
There's not much to see on the display/keyboard PCB. An
NXP PCF8576CHL LCD driver and that's about it. The display itself does not have any manufacturer markings but it's clearly a custom job for Weller. There are a few unoccupied islands left from the display. The layout suggests that it's for 2 LEDs and their current limiting resistors. I guess this is for a backlight that, sadly, never materialized.
The small connector in the top left corner is for the status LEDs above the output connectors.
A closer look at the main PCB:
The brain of the Weller WR 2 is a
PIC18F6722-I/PT microcontroller. Just as with the
Weller WHA 900 I took apart earlier there's an unmarked jumper near the microcontroller. I did not have the guts to try it out. I wouldn't be surprised if it clears calibration or other critical data for operation. Right from the microcontroller, on the edge of the PCB, is a seemingly unused 10-pin header which is most likely the programming interface. Exactly the same header was present in the WHA 900.
The (de)soldering tools are powered through the two TO-220
BT138X-600 triacs and their
KTLP160J triac drivers - one for each channel. The 5 V power supply for the electronics is provided by the TO-220
MIC2937A 5.0WT low-dropout voltage regulator in the top left corner. In the center of the board is a TO-220
IRLI530N power MOSFET to drive the pump. In the lower left corner is a pressure sensor but sadly it did not have any part number markings on it. It is used to measure the vacuum during desoldering.
The main PCB is clearly shared with the higher end WR 3(M) which features 3 channels with up to 200 W per channel, an extra pump and USB connectivity. The islands for the third output are visible below output 2, the islands for the USB interface are on the lower right edge and the islands below the heatsink suggest there can be quite a few more TO-220 power houses.
At first I was a bit puzzled by the amount of unpopulated TO-220 components. The WR 2 has 2 triacs and the WR 3(M) has only one extra channel, but there are 8 open TO-220 triac positions on the WR 2 PCB making up for a total of 10 triacs (ignoring the right most unpopulated TO-220 because that's clearly a voltage regulator judging by the layout of the components around it)? In fact some of the pins on output 1 and 2 go to the unpopulated TO-220 triacs. So even the available outputs of the WR 2 clearly do not support some things. What's going on?
The higher end WR 3(M) supports more tools like the WMR active tip series. These are 12 V tools unlike the traditional 24 V Weller tools. The 12 V tools have 2 triacs per channel to support tools with two heating elements (tweezers). So that's one triac per channel for the high power 24 V tools, and 2 triacs per channel for the 12 V precision tools - 9 triacs in total. But wait... There are 10 triac positions on the PCB? That's because output 1 has an extra 24 V triac for the HAP 200 hot air pencil (it has two heating elements). That's why the HAP 200 cannot be used with the WR 2 and even on the WR 3(M) it works only on output 1.
That's it! I hope you liked this mini-teardown!
