What i have found at my DSO-X2002A:
ProsUpgradability.
The scope is easy to operate thanks to the pushable knobs. Much better than GW Instek or Tektronix. Why don't they use pushbuttons?
It is better to buy a scope that is being manufactured for two years or so. There always might be problems with the first units built.
Installing the new firmware was easy. Evereyone can download it at Agilent webpage.
Buy this scope if you will often use the XY mode, OK, only a few people actually need it. But it has XY cursors and even Z-blanking.
It has two USB ports for flash disc.
The fan is large and quiet, but I cannot compare it to the Rigol DS1000.
The free wavegen (function generator) is great. It has even AM FM and FSK.
The machine is quite large and heavy, someone might want a Hameg HM2024 Instead.
It never tends to fall down when you push a button.
I obtained free papers with certificates for DVM and WAVEGEN. It was also easy to download the licences from Agilent web. The DVM is nice.
The waveform update rate is as fast as Agilent specified in datasheet. It can be easily measured by a cheap multimeter with counter. The waveform update rate doesn't go low when you use two channels or even FFT.
I couldn't find a firmware bug. Is there any?
I like the separate
cursor knob.
Minor cons: It has no beeper.
The probes are fixed at 1:10.
There is no real 230V power switch, it consumes about 5W when "switched off". Well, this was no surprise to me, i saw Dave's video.
While the scope is quite heavy, the plastic handle is rather small and maybe not so hard-wearing??
The scope is always in vectors mode, no way to switch to dots.
There is no memory setting or info in the menu. But I measured that in
Single mode the scope uses 100kpoint per channel. When in
Run/Stop mode, it uses 50kpoints per channel. It doesn't matter if you use one or all two channels. It is somehow mentioned in the manual.
Not possible to use both cursors and auto measurements.
No alt trigger mode. But only a few middle class scopes have it.
Only four automatic measurements at one time + DVM.
It is not possible to do serial decoding when digital channels are on.
Only a few trigger modes. But no problem with that.
Not possible to create folders on USB in scope.
