Author Topic: UK Sky 2TB WiFi Boxes - 10 Pin I/O Pinout needed  (Read 4180 times)
Offline ClintTopic starter
« on: November 07, 2013, 11:30:36 am »
Does anyone know where I can get the pinouts for the 10 Pin Mini Din Plug on the new Sky Boxes ?
g33K5 L1k3 80085
Offline fluxcapacitor
Re: UK Sky 2TB WiFi Boxes - 10 Pin I/O Pinout needed
« Reply #1 on: November 09, 2013, 09:06:34 pm »
i don`t know the pinout,but if you`re wanting to watch tv in other rooms with one of the new sky boxes you`ll need a link modulator.
http://www.satbuyer.co.uk/global-io-link-modulator-tvlink-p219.html
Sky sell them on their accessories page for £25
« Reply #2 on: November 09, 2013, 09:08:19 pm »
I want to make one, actually I only need the remote signal shoved up my coax, but Ill guess Ill need to do a tear down and work out the signals, only issue is I kind of failed the EEV rules as I already turned it on.
g33K5 L1k3 80085
« Reply #3 on: November 09, 2013, 09:09:01 pm »
Oh did I mention Sky are a bunch of F***wits !!!!!!!!!!!!!
g33K5 L1k3 80085
« Reply #4 on: November 09, 2013, 09:22:44 pm »
Yes they are.If you call cutomer support and threaten to leave you might be able to squeeze one of those global io boxes out of them.
« Reply #5 on: November 09, 2013, 09:42:19 pm »
And there is another problem, currently I have 2 TV's and apparently the signal isn't strong enough and especially if the coax is quite long, anyway I cant wait 2 weeks until they think they will have stock again.
g33K5 L1k3 80085
« Reply #6 on: November 09, 2013, 10:02:17 pm »
you could try a signal amplifier ,but it shouldnt be used with cable less than 30 metres .
« Reply #7 on: November 09, 2013, 10:07:32 pm »
I dont think the signal is the main issue its the low power in the 9v line, but I am not sure without having one.
Its going to be quicker to make one to suit my needs.
g33K5 L1k3 80085
Offline urbis
« Reply #8 on: December 08, 2013, 10:19:39 pm »
Can you keep us up to date if you work this out?
I'm not sure the modulator is internal, I have a feeling it's actually built into the IO Link box.
