BISS0001 datasheet
http://www.ladyada.net/media/sensors/BISS0001.pdfdoes anybody know a link for a datasheet for CO15P or is it C015P ?
out-put switch 8pin ic ? I will assume the chip is under 400Ma and needs a reverse blocking diode to drive a relay coil.
got two sensor units but distrust the wiring colors, so I needed to take a peek inside one, discovered no relay coil.
Teardown of a Cheap Outdoor Light Sensor
teardown of a Chinese made outdoor PIR passive infrared motion sensor , this is the 12 volt unit..
as sold by e-bay & aliexpress. the electrical wiring colors is some-what odd.
maybe potentially dangerous?
also sold is a 220 volt unit, that I have not done a teardown on.
if your interested here is my video and links
Cheap Out-door Light Sensor
