The hard part is knowing the frequency range of the material. AL does not interest me much.
I need to know
43 NiZn material at 100MHz, lossy or not.
With beads for through-hole part leads, like a mosfet or 1/2W resistor, does it saturate at a few amps or not.
This kind of thing I have to keep in mind.
I have a cable ferrite clamp-on kit from
FerriShield/LeaderTech that has been good for solving EMI problems/drama out in the field.
At a 240kV substation, the SCADA D200 computer crashed from EMI when the breakers open and the arc. The burst comes in on all the yard wiring and corrupts all kinds of serial data.
At an EMC test facility, clamp-on's help to narrow down the radiator and mode for experimenting or when you need a last resort to pass.
