Pics are here:
http://www.hacklordsniper.com/Arhiva_projekata/Projekt_(36).htmlFor the most pretty picture of teardown go directly here:
http://www.hacklordsniper.com/Slike_projekata/Projekt_(36)/Slika%20(18).JPG The projector is great, noise is quite acceptable, build quality is great except little flaw. The front leg is not in middle so projector can swing on left or right site. The is no focus drift with heating as reported on some forums, basically it does not heat much.
Any questions, ask.
PS. For the nerds the test photo is in the topic. However don't trust the camera, the projected image is superb, sharp and clear (you can surf and read on line without any problem or eye fatigue)
There is a photo in dark and in light room, there is not enough brightness for a bright room.
