Keep searching and try higher numbers you might find a different one but a lot of chinese stations have very limited tip ranges (aside from the designs they copied from Hakko). Also look at the wattage of your station and search on aliexpress.com and dhgate.com etc (chinese websites) for "48w soldering station" etc, you might find it under other brand names. You can also try looking under google images as well when you get it a hit, sometimes it yields good links to sellers.
To thank posts, there is a little thumb button "say thanks".
