Author Topic: What is the best KSGER T12 Soldering Station?  (Read 2052 times)
Offline DokromaTopic starter
« on: July 03, 2020, 05:01:08 pm »
There's multiple versions of this soldering stations on multiple sites such as Aliexpress, Banggood etc. Which one is the best one?
Re: What is the best KSGER T12 Soldering Station?
« Reply #1 on: July 04, 2020, 04:22:48 pm »
Update: I bought https://www.aliexpress.com/item/32983347123.html
It has wired connections from mains rather than edge soldered joints and the case is plastic. What mods do I need to do?
Offline Alokin
« Reply #2 on: July 06, 2020, 07:08:22 pm »
I would simply cut the edge of the heatsink that is on the HV rail, put some kapton between the rail and the heatsink and as the case is plastic, run a wire to ground both the rotary encoder and the handle connector, if the front panel is made of aluminium scratch it under the bolts to make a proper connection.
The following users thanked this post: Dokroma
« Reply #3 on: July 07, 2020, 10:25:25 am »
Thanks, I was planning to do these already. Anything else I should do? Perhaps use lower amp fuses? Aren't the 5A fuses excessive?
Offline Gyro
« Reply #4 on: July 07, 2020, 11:32:34 am »
Probably intended to support the US. For a 230V country, you could probably just about halve them (Anti-surge).
Best Regards, Chris
« Reply #5 on: July 07, 2020, 02:35:43 pm »
So, I think the max watts of the station is 175W, so you need atleast a 1A fuse right? 2A is the appropriate fuse to use?
