Author Topic: Miniware MHP50  (Read 31890 times)
Fire Doger and 2 Guests are viewing this topic.
Offline Pandor
Re: Miniware MHP50
« Reply #25 on: March 14, 2024, 06:34:15 pm »
I was about to order this puppy, but what is the difference between the Aluminum with Anodized Surface plate, and the Brass with Nano Ceremic Coating plate? I know the 30*30 only comes in Brass, so why the anodized Alu? Is there any benefit to that one?
Offline orzelTopic starter
    • Sylphide Consulting
Re: Miniware MHP50
« Reply #26 on: March 14, 2024, 07:25:31 pm »
I have no idea. I took the ceramic one out of random.
Offline _Harry_
Re: Miniware MHP50
« Reply #27 on: March 15, 2024, 12:33:03 pm »
asked that myself too.
Have you seen this?
2073584-0
Physically:
Aluminum has better thermal conductivity than brass; that's why they say, alu has a "more evenly heated surface". But considering the small area of 5x5 cm, I don't think there is much difference between the aluminum and brass MHP50.
Brass is not as "hard" as Aluminium. That could be the reason, why they spend an nano ceramic coating in addition; as side effect it is easier to clean. I read somewhere, that brass needs more time to reach the same temperature compared with aluminium.
Regarding the more evenly heated surface my decision was for the AL50 Hot Plate.
_________
 - Harry
Re: Miniware MHP50
« Reply #28 on: March 15, 2024, 12:43:36 pm »
I confirm it's very easy to clean. I expected it to be more difficult..
Offline Pandor
Re: Miniware MHP50
« Reply #29 on: March 15, 2024, 07:26:32 pm »
Have you seen this?
(Attachment Link)
Physically:
I did have a look at their website beforehand, and seen the picture you're refiring to but the "shine bright like a diamond" didn't make much sense.. must be lost in translation somewhere  ;D
How easy is the anodized surface to clean from flux and smeared solder?
I'm tilting towards the brass plate, but not sure. Maybe there's less hot/cold spots (before fully reaching set temp), so a more stable heat spread with the alu? that could be and advantage when using the reflow option it has...
Offline _Harry_
Re: Miniware MHP50
« Reply #30 on: March 16, 2024, 11:37:52 am »
About AL55 surface cleaning - I have no experience. I returned my MHP50 because
  • I got one with PCB v0.7
  • The reflow welding temperature can't be set below 230 °C (at least with FW v1.0). That's bad for low temp. soldering (e. g. 150 °C), as you unnecessarily stress your PCB with much more heat than actually needed.
The build quality at all was really very good. Only the spacing between the temp. digits was not perfect on the display; that could be improoved by a FW update.
« Last Edit: March 16, 2024, 11:40:22 am by _Harry_ »
_________
 - Harry
Offline ius
Re: Miniware MHP50
« Reply #31 on: April 05, 2024, 12:52:04 pm »
It is recommended to prepare a power supply that supports the PD3.1 protocol. In the upcoming MHP50 firmware, we have added PD3.1 protocol support and can work at 140W power.
Note that in fact it is already supported in SV 1.00 (which everyone seems to already be on). I got a 28V PD trigger (for 28V DC input, which is also supported) but turns out there's no need.
Make sure you get a 140W PD3.1 power supply and a 240W rated cable: the one Miniware provides only supports up to 20V/100W.
There is no '1.00' and apparently Miniware felt it was ready for market. I don't see the point of returning it over a number which has little meaning if you're not the manufacturer.
Agree on the second point though. It seems to be an arbitrary limitation - hopefully they'll fix it in a future firmware update.
The following users thanked this post: thm_w, orzel
Offline _Harry_
Re: Miniware MHP50
« Reply #32 on: April 05, 2024, 03:09:19 pm »
Believe me or not. No professional industrial company would start final PCB series below rev 1.0.
They call those "prototype" or  "0-series".
And ask yourself, why they stated "H_Ver: 1.0" in the manual - someone at miniware / e-design knows that very exactly ...  ;)
Anyway - 0.7 seems to work properly. Have fun!
_________
 - Harry
Offline thm_w
  • Non-expert
Re: Miniware MHP50
« Reply #33 on: April 05, 2024, 09:45:43 pm »
What? Revision numbers are completely arbitrary, I could start at A or 0.0 or 0.1 or 1, or 0, or whatever you want.
Even if your statement was true, this is not a "professional industrial company" they are just making low cost soldering products, primarily for hobbyists.
Re: Miniware MHP50
« Reply #34 on: April 05, 2024, 10:27:58 pm »
...  they are just making low cost soldering products, primarily for hobbyists.
I (respectfully) disagree. The MHP50 is expensive !
The following users thanked this post: fichamba
Offline thm_w
  • Non-expert
Re: Miniware MHP50
« Reply #35 on: April 06, 2024, 12:02:30 am »
For hobbyists yes you are right. As a comparison, though not quite the same product, Hakko's low end preheater is $360, metcal $600, pace $1,200.
« Last Edit: April 06, 2024, 12:04:23 am by thm_w »
Offline SteveyG
  • Soldering Equipment Guru
Re: Miniware MHP50
« Reply #36 on: April 25, 2024, 08:17:39 am »
Apologies for the long delay, I've release the video on this finally.
It took a while for my PD3.1 power supply to arrive, but it works well at 28V
YouTube Channel: https://www.youtube.com/user/sdgelectronics/
Use code: “SDG5” to get 5% off JBC Equipment at Kaisertech
Offline thomasx
Re: Miniware MHP50
« Reply #37 on: May 01, 2024, 10:51:03 am »
Greath thread!  :-+
Any supplier in Europe having the MHP50 in stock?
AliExpress does not seem to have in any of their European warehouses.
I need one urgently :)
Offline Mattchu
Re: Miniware MHP50
« Reply #38 on: May 10, 2024, 10:30:00 am »
Hey all, this is my first post so hopefully I don’t butcher this too hard…
I’m a bit confused whether the BS-50 plate is brass or copper…
I took a look at the actual miniware website for this product https://e-design.com.cn/ProductDetail/9555590.html and I noticed that it kept saying “copper” rather than brass (I think?) in chinese.  The product listing was saying 铜 (copper) rather than 黄铜 (yellow copper, aka brass).  As a sanity check I went to their MHP30 page, and there it specifically said 黄铜 (brass) so these products are definitely listed as having different materials.
Not too sure what to think about this, everything in english is saying brass but would they really write the wrong material in their main language then put the correct one in english?
Anyways, I want one, should I get the Alu or the ?brass/copper? One?
Offline thm_w
  • Non-expert
Re: Miniware MHP50
« Reply #39 on: May 10, 2024, 08:48:22 pm »
BS-50 would imply brass. But its very common for 3D printer parts to mix up brass and copper, and just call it copper colored metal or something.
Aluminum will heat up faster, brass will have greater thermal capacity. If you want very fast temperature ramp get Alu, if not brass should be good, more consistent temperature.
Brass: ~140 W/mK, 8.7g/m3
Alu: ~220 W/mK, 2.6g/m3
The following users thanked this post: 2X, Svgeesus, orzel
Offline 2X
  • Country: gr
Re: Miniware MHP50
« Reply #40 on: June 15, 2024, 01:59:33 pm »
But how to choose the material of the heating table? Which one is suitable, copper or aluminum alloy
Online artag
Re: Miniware MHP50
« Reply #41 on: June 15, 2024, 04:21:32 pm »
It is a bit overpriced.  But the segment is underrepresented.  And Miniware are riding on their name a bit.  I bought the TS100 when it first came out and to this day it still works.  So at least I have some faith in the quality of their products.
I have a TS100, I bought it after the first flush but before all the clones appeared. I'm still pleased with it but I had to replace the Oled display. It faded and died quite quickly. It came from an ebay supplier who specifically said it was the right size for a TS100 .. why do you think that might be ?  :)
I also have an MHP30. Apparently my TS100 experience was good enough to encourage that :). I find it useful despite it's small size but have now bought a much bigger 200mm hot plate, mostly for doing assembly a bit faster than the MHP30.
I think the Oled is fading, so it may be going the same way as the TS100, though not as fast. I'm not sure why this is - do Miniware overdrive them ? Use a bad source (my replacement TS100 display has now lasted longer than the original).
Online artag
Re: Miniware MHP50
« Reply #42 on: June 15, 2024, 04:25:21 pm »
These are pretty cheap. Some suppliers play silly games with the shipping cost.
https://www.aliexpress.com/item/1005005968258483.html
I'm not saying they're comparable in quality with Hakko, Metcal or even Miniware. But they may be adequate.
Offline fichamba
    • jngpro
Re: Miniware MHP50
« Reply #43 on: July 11, 2024, 06:13:16 pm »
Hi everybody!
I have the MHP50 and it's amazing. A bit expensive?, well, maybe. But it is extremely well made. I have the aluminum one. And it's FAST!.
BUT, I have a problem: I can't update the FW!. It comes with V.1.00 and I had downloaded 1.01, followed the (minimal) instructions, but no device appears like a USB pendrive in DFU mode (the screwdriver does). Could you comment something to this regard, please?. I am doing it in a Windows 11 Home PC.
TIA
EDIT: SILLY ME!!! I was connecting the MHP50 to the computer via a charge-only cable!. Now it has FW V.1.01  8--------)
« Last Edit: July 11, 2024, 06:22:56 pm by fichamba »
The following users thanked this post: 2X, orzel
