Author Topic: CFW for KSGER/Quicko STM32 Soldering Stations  (Read 823484 times)
Offline DavidAlfa
Re: CFW for KSGER/Quicko STM32 Soldering Stations
« Reply #4150 on: June 26, 2024, 08:45:21 am »
No need of so, it will automatically turn power off when tip is removed?
If you want more time when switching tips, you can increase Error Timeout, so it waits longer.
2 seconds is a pretty good value.
« Last Edit: June 26, 2024, 08:51:32 am by DavidAlfa »
Offline LILO
  • Country: ru
« Reply #4151 on: June 26, 2024, 09:02:19 am »
I think the point is to cool down the tip before removal wo touching encoder knob.
Offline DavidAlfa
« Reply #4152 on: June 26, 2024, 11:47:24 am »
Anyways the tip won't cool down just because you remove the power, it will take several minutes.
Offline clytle374
« Reply #4153 on: June 30, 2024, 09:23:29 am »
Well, I got it done.  And it works.
The following users thanked this post: dcore
Offline dcore
  • Country: pt
« Reply #4154 on: June 30, 2024, 03:49:22 pm »
Can't see for sure in the photo, but looks like U2 middle pin is not soldered.
When you use smart active, what's the lowest load value you can get?
The lowest I can setup in my ksgers is 6, the other ksger needs 8 (I use c245 in both).
It's much better using smart load when soldering, specially if it's a larger copper mass.
I'm really happy using this FW, thanks @davidalfa!
« Last Edit: June 30, 2024, 04:14:01 pm by dcore »
Offline clytle374
« Reply #4155 on: June 30, 2024, 08:22:15 pm »
Very good eye.  I had the boards made without through hole components, and without the expensive opamp for cost reduction.  I'm switching to night shift and missed it in all the excitement.  Safe to say you caught it way faster than I did   ;D
Just to avoid getting a bad comparison, and I've never used it before, what is your test method?  Let me know and I'll get you a number.  I'm using T12 tips.
Offline clytle374
« Reply #4156 on: June 30, 2024, 08:49:12 pm »
I think I figured it out.  Nice that the shake icon blinks when it's triggered.  So I can get it down to 3, if I hold my breath and not breathe on it.  4 if I want to breathe freely.  It can easily detect wetting the tip with solder.  Very cool feature.  Very very fine work by @davidalfa Thank You!
Here was how I was testing since I don't have a proper stand.
Offline dcore
  • Country: pt
« Reply #4157 on: June 30, 2024, 09:59:19 pm »
How to setup the Smart Active Load is on DavidAlfa github in the operation instructions.
« Last Edit: June 30, 2024, 10:03:12 pm by dcore »
Offline clytle374
« Reply #4158 on: June 30, 2024, 10:46:40 pm »
I found it, see my second reply above.  my t12-j02 tip definitely requires a 4
Offline ststefanov13
  • Country: bg
« Reply #4159 on: July 02, 2024, 05:28:14 pm »
For the information of all colleagues regarding the compatibility of T39 soldering tips of Hakko FX-971 FX-972 .
 Soldering tip connector is same as T12/T15.
With David's firmware it works perfectly, only the heater is changed = 5.7 ohm, power 100W. The thermocouple connected in series to the heater is the same type.
Original HAKKO FX-971 FX-972 handles can be used after replacing the connector with GX-X.
T12/T15-К  23.65 EURO
Т39  - 25 EURO
~1.5 ЕURO = +20W
« Last Edit: July 02, 2024, 06:33:06 pm by ststefanov13 »
Offline wasyoungonce
« Reply #4160 on: July 11, 2024, 07:56:02 am »
First Stupid question of the day...looking at buying one of these to try T12.   Should I buy the Ksger ver 3.1 (supposed to be STM32 IC) or Quicko T12-958 (I'm not sure of the handle differences here, supposed to be STM32)
Prefer FX9501 alloy handle not sure of differences or if they some have sleep jiggle etc  I'll be after a few extra cassette tips etc Like T12-BC3M/2M and others (Ksger doesn't have)
Sorry if its be discussed...I did look   Those T39 tips look good
edit this answers handles used
https://www.rchelicopterfun.com/t12-soldering-station.html
The 907 handle is very similar to the 9501 handle. It uses the same T12 soldering tips, has the same NTC & motion switch and still fits in the KSGER T12 clone iron stand I mention later on in the review.
« Last Edit: July 11, 2024, 08:08:40 am by wasyoungonce »
I'd forget my Head if it wasn't screwed on!
Offline clytle374
« Reply #4161 on: July 11, 2024, 08:14:50 am »
I recently bought 2 of the "KSGER T12 Soldering Iron Station STM32 V3.1S OLED" from Aliexpress.  Both the line powered and the 24V powered.  Both had MM32 processors and the NTC on the control board without it being wired to the output connector. One handle had the NTC the other had a place for one, but no conductor for it.  I replaced the MM32 with a real processor on one and killed the other for R&D to design my own.  I can't help with the other questions, sorry.
« Reply #4162 on: July 11, 2024, 08:24:26 am »
many thanks...guessing the Quicko t12-958 is thus best way fwd to get stm32 IC
Edit I saw and note your open source T12  Very nice
edit 2: The PCBs (on all) really need rivets for the connector!
edit 3: Quicko T12-958 ordered plus tips we shall see
« Last Edit: July 11, 2024, 10:15:25 am by wasyoungonce »
The following users thanked this post: clytle374
