what makes you think the transformer is dead
it is very rare
anyway I got one recently, a battery charger to fix
measure ohms between the primary gives infinite... open loop.
you must know that there are fuses in the primary of recent transformers...
I teared down the transformer, unwind some wires, and I founs a little fuse in it
replaced the fuse, rewinded, and everything is ok now...
In my case, the transformer was also unknown by internet, special windings.
good luck.
