For production use, I'm impressed with Metcal (500). Instant joints and you never have to stop to clean the tip. It seems like the Curie effect produces an instant standby/full-throttle. You can throw all the PID algorithms and power you want at a soldering iron, but you can't take out the thermal lag between the tip and heater/sensor. Until the sensor can read your mind, it will always be one step behind.
I'm not familiar with Thermaltronics. I've used $300 Wellers, cheap generic junk, and I have settled on a small Hakko FX for myself. The difference between any of these irons to me is essentially squat and comes down to ergonomics and cost effectiveness. I was genuinely surprised by the Metcal.
I made my own battery powered, portable iron that runs on standby (slightly above solder melting point) by default. When you push a button, it goes full throttle for a couple seconds. In practice, you push the button, wait a second, then make the joint(s). It works great (on smaller joints), and I never have to clean the tip of that iron. The Metcal seems to approximate that, automatically. I'm convinced that in practice, instant and appropriate POWER regulation beats any attempt at TEMPERATURE regulation. It doesn't matter if the temp of the Metcal goes up if you hold it on a joint for 10 seconds. It doesn't matter than a JBC can hold that joint at exactly X degrees, indefinitely. When the joint reflows, you usually remove the tip. The practical reason why we turn the temp down on our irons where we can isn't to protect delicate electronics from thermal damage. It's to keep the flux from burning up and having to clean and replace tips more often.
