2mm sounds a bit small. I can't find my vero spot face cutter at the moment, but I think it's more like 3mm [Edit: I suppose it can't be quite that big!], allowing more copper removal in a smaller number of turns. I remember seeing magazine adverts for the original cutter, when veroboard came out, it looked to have a center pin but I never saw one in the flesh. The modern ones are just a spade drill shape, A standard drill in a piece of wooden dowel would be just as good.
