Author Topic: Metcal F Connector  (Read 2094 times)
Offline l0wsideTopic starter
Metcal F Connector
« on: November 29, 2016, 10:44:29 am »
I have a used Metcal transformer unit (STSS-PS2V-02) from eBay and thought to complement it with a new handpiece MX-H1-AV (and the corresponding tips).
Unfortunately, the F connectors do not match. They have the same diameter (9.5mm outer diameter), but different thread pitches. The transformer unit looks like regular pitch, while the connector on the handpiece side seems to have some fine pitch thread.
Does anyone know the problem and/or have any suggestion? Replacing the connector on the handpiece side would be the most plausible option, but I am somewhat reluctant to treat some brand-new equipment with pliers and knives.
Max
Offline Skashkash
Re: Metcal F Connector
« Reply #1 on: November 29, 2016, 11:18:57 am »
The connector does not thread on,.
It pushes on, and then the ring on connector tightens.
Try unscrewing that ring first, before attaching.
« Reply #2 on: November 29, 2016, 01:11:58 pm »
Skashkash, you saved my day. Thank you. If you ever come over, I owe you a beer.
Offline stj
« Reply #3 on: November 29, 2016, 05:48:13 pm »
the push-on bit is available as an adapter for regular F plugs, i had one on the bench when i did a lot of satellite receiver repairs.
Offline Skashkash
« Reply #4 on: November 30, 2016, 12:57:00 am »
I went the same Metcal route as you.
 Bought a used power unit on ebay and a new handle from a distributor. I remember that the squirrelly F connector confused me at first too. I'd never seen that one before. And I've seen a lot of F connectors.
I've used a lot of soldering systems over the years. The metcal is the best I've ever used. But I'm sure other's will have differing  opinions and experiences.
Have fun with yours.
Now I just have to get over to Germany for that beer.
