Strangest thing is, you being angry with me, for your own words, claims, statements, failures, and ignorance.
![Blah :blah:](https://www.eevblog.com/forum/Smileys/default/blah.gif)
And, no, I see nothing "inferior" about the ~$1.00 50W ceramic heaters, or whether they are made by "THE GREAT GOD OF CHINESE JUNK", or "THE GREAT HAKKO GOD."
50W is 50W ... and as I have pointed out, if someone supplies me with a unit, heater and tip made by THE GREAT HAKKO GOD, and I solder a board, or I use my equipment made by "THE GREAT GOD OF CHINESE JUNK", you, or no one, would ever know the difference -- despite the claims which might be made by the terminally insane.
Indeed, using only common sense, and choosing HEAVY tips, 900M-T-1.6D, at a cost of 0.64 each, when purchased in single quantities, I see no difference in the actual performance of the unit made by the hakko god vs. the cheap chinese god.
... and I don't need to measure it ... I believe my eyes and senses ... you simply need to make sure you have the RIGHT cheap element for your CHEAP stations ...
![Popcorn :popcorn:](https://www.eevblog.com/forum/Smileys/default/EatingPopcorn.jpg)
Here is such a tip, since the tip is the single most important component:
http://www.aliexpress.com/item/900M-T-Cusp-Series-Soldering-Oxygen-free-Copper-Replacement-Iron-Tip-For-Hakko-936/32514968228.html?spm=2114.01010208.3.2.EGAjEx&ws_ab_test=searchweb201556_7,searchweb201644_1_505_506_503_504_10020_502_10014_10001_10002_10017_10005_10006_10003_10021_10004_10022_10018_10019,searchweb201560_9,searchweb1451318400_-1,searchweb1451318411_-1&btsid=19ae7640-a025-4ddb-8ecb-1162be6e7028If your A1321 element is a loose fit, shim the tip with a bit of 0.001+ copper shim stock, or if too tight a fit, ream the tip with a proper drill to secure snug fit.
