I watched a video whereby someone was testing a single phase motor and chose the first highest reading as the START winding
After googling other articles to help me better explain how to carry out the test i found conflicting results whereby; the highest reading of the windings were between run and start therefore making the start winding the second highest ohm reading .
https://www.electricalengineeringtoolbox.com/2015/12/how-to-test-and-check-single-phase.htmlWhat are the correct readings to focuse on finding the run , start and common winding
