Author Topic: Medical Alert Pendant Teardown  (Read 776 times)
Offline jonovidTopic starter
    • JONOVID
« on: March 08, 2023, 03:36:02 am »
its 4G phone electronics and SIM with out a screen or keypad.
only two buttons on the case.
one Lithium-ion 800 mAh 96Wh battery
 mic & speaker also mini vibration motor or shaker.
plus 7 gold pogo pins.
the products two yr life expectancy had expired.
Hobbyist with a basic knowledge of electronics
Offline Krotow
  • Country: lv
Re: Medical Alert Pendant Teardown
« Reply #1 on: March 10, 2023, 06:42:11 pm »
Charge the battery in LiPo/Li-Ion battery charger and it will work again. If battery is dead, you can replace it to similar Lipo battery with protection circuit. Like this
https://www.aliexpress.com/item/32996924752.html
Offline jpanhalt
« Reply #2 on: March 10, 2023, 07:39:30 pm »
I had a "free" one offered by my Medicare intermediary (age 80).  My thinking was that the idea sounded good for someone living alone in a rural area.  After 2 weeks, I turned it off and tried to return it.  The Medicare intermediary wasn't interested.  It was disassembled, then put in the trash.
Problems:
1) False alarms.  My contact person (daughter) ws worried to death.  She survived.
2) Rural community, trees, and medi-alert do not work well together.  Most of the time there was not 2-way communication, hence the false alarms.
Solution:
I send an email when I start some dangerous thing outside, then cancel the alert to my contact person when I am done.
    • JONOVID
« Reply #3 on: March 12, 2023, 04:43:00 pm »
the product has a two yr life expectancy then its replaced. even if it working ok.  so it become e-waste. I do not waste Electronics, I post images on eevblog then re-use the 96Wh battery for other projects. dismantle any or all of it.  google part numbers , look for any re-use I can get from it .
the gold =$
