Author Topic: Looking for hot air station  (Read 6052 times)
ZigmundRat and 1 Guest are viewing this topic.
Offline Raziel92Topic starter
« on: July 22, 2023, 03:29:33 pm »
Hello, im looking for a new Hot Air station
Mostly ill work on desoldering/soldering QFP
Im looking for the high reliability since it will be used in full time work
My budget is about 500-700 euro, at the moment im aimed on
Aixun H310D (ATM im using also T420D which i love)
Im a bit afraid of the building quality, mostly due to SMPS
Sugon 8650
Quite good building quality but the glass painted keybuttons looks so cheap and probably will lost their painting after a while (i know its just a detail)
Quick TR1300 (non A wersion) which is probably the best but its over budget right now
Offline Faranight
  • Country: si
Re: Looking for hot air station
« Reply #1 on: July 22, 2023, 09:03:28 pm »
I'm using Quick 861DW, and with proper nozzle it works wonders with TQFP, QFN and DFN and even some smaller SMD components like 0603 and 0402. Note that I'm mostly doing soldering by hand with a proper magnifier and tweezers. For QFP's you technically don't need a hot air station (unless there's a thermal pad present on the IC), but it can work too. I simply use a hoof tip nozzle on my soldering station and a lot of flux. Also works wonders.
e-Mail? e-Fail.
Offline mastershake
« Reply #2 on: July 23, 2023, 04:37:27 am »
i would def skip the 310 for now personally. if i have to be honest one of the units i use more then any other here now is the best bst with the modified pcb board in it. its fantastic with the new board installed. but it does add a bit of cost. otherwise id go for quick. when these are made well they last a really long time so i recc spending a bit more instead of having to replace a cheap junk one many times. most of my techs are using the best bst with the added pcb (to give you dials) and they tell me they reach for that more then even the quick unit. those dials make it so fast and east to change temps and air speed on the fly as you need to.
Offline Psi
« Reply #3 on: July 23, 2023, 05:24:02 am »
I like the Atten ST-862D
I've heard good things about the Quick 861DW as well, never used one though.
« Last Edit: July 23, 2023, 05:25:39 am by Psi »
« Reply #4 on: July 24, 2023, 07:32:58 pm »
I think ill give a try Sugon 8650
« Reply #5 on: August 02, 2023, 06:11:45 pm »
Sugon 8650 arrived, what I can say, what a beast.
Internal built design is very good as for chinese manufacturer, probably it will work fine for years, if not distributor in Poland has huge spare parts inventory, f.e heater for 25 euro, whole handle with heater 50 euro, there is also the turbine, power supply pcb, front end pcb but I didnt asked the prices for them, i think they will not cost much.
Everything is excellent except the plastic chrome buttons, but I can live with that
The following users thanked this post: thm_w, mcconkeyb
Offline Psi
« Reply #6 on: August 05, 2023, 05:46:09 am »
I like how you can see what all the presets are before clicking on them with the Sugon 8650
Offline mcconkeyb
« Reply #7 on: February 28, 2024, 12:23:17 am »
Did you get all of the nozzles as advertised by Sugon with your 8650? Mine just arrived and only 4 of the 8 nozzles are provided.
Offline Psi
« Reply #8 on: February 29, 2024, 10:01:11 am »
Since my last post we got a Quick 861DW at work.
Great machine. When my china Aoyue station dies that is what i'm buying.
One minor annoyance about the Quick 861DW though, is accidently bumping the button on the hand piece and turning off the iron while trying to use it.
However I think you can change that button to do nothing, have not checked manual yet but I was told you can change its function.
« Last Edit: February 29, 2024, 10:04:35 am by Psi »
Offline KE5FX
    • KE5FX.COM
« Reply #9 on: July 14, 2024, 05:41:11 pm »
Interestingly the 8650 that I just bought no longer has chromed buttons, but matte black.  Maybe they heard your complaint.
I haven't actually soldered anything with the 8650 yet, but it looks good so far.  Memories and state are retained across power cycles, the display is great, ergonomics seem well thought out, and the UI is very capable (although some features require at least a brief pass through the manual.)  You get the impression it was designed by people who used similar products and wanted to do better.
Offline digger
« Reply #10 on: July 14, 2024, 07:24:51 pm »
ha, i actually like the chrome look. too bad.
can you post a pic of your unit?
Offline KE5FX
    • KE5FX.COM
« Reply #11 on: Yesterday at 01:47:07 am »
Note that "MODEL" is still misspelled on the PID damping control button at lower right...
