Basically, i want a flexible drill press, small, I'm on a very limited budget. How limited? i was hoping I could find something for well under $100, thats good enough quality to be used for a long time. (Not a Dremel-style-tool add on device, at least not the one which ive heard so much criticism of)
I just want a solid, very basic small drill press. No frills, for drilling PCBs accurately.
It would be nice if it was small enough to put away on a shelf when not in use.
I already have a fairly decent small jacobs chuck that I bought at an estate sale. (Edit, it is a very nice quite small model 0 stainless steel chuck that is ideal for electronics- the previous owner was an electronics engineer - Retail on it is $170, so its a nice chuck-) It has an additional "micro touch" wheel and extensible shaft so it can be used to drill very light precise holes. I would like to be able to use that.
Basically, while it is drilling you can push it down with your finger rather than the lever, by pushing on a freely rotating ball-bearing mounted aluminum ring. Its my understanding that it can be used for precise drilling.
It would be great if in the future I could use whatever I buy as a basis for an automated stage - add an X-Y stage that could be motorized to automate PCB hole drilling.
My main problem with doing what I am doing now (using a Dremel-like tool by hand) is uniformity. The holes wander enough to be noticeable. I would like to be able to use the drill press with a jig to make drilling holes precise and easy to space at exactly the same distance apart.
Also a stable drill press is easier to set up with a dust collector of some kind.
