During a recent power outage my UPS failed to work!! Anyway checking the batteries showed they we U/S. Replaced and all seemed OK i.e. they charged up OK. On test with a load connected the unit switches over OK - but shows no load % used, then shuts down after a couple on minutes. The manual mentions if the UPS "appears to see no load" it will turn it self off after a minute or 2. The unit appears to work otherwise i.e. the capacity decrements as expected. So I guess if there is some way to turn off the "no load" option it would be a cheap fix, otherwise looking for ideas or circuit.
Thank You
