BlackIce: Just see now.
I was EE/ekectronic ballast designer in 1970s..1990s, flour, CFL, HID, HMI, cinema
with Laurench Berkeley Lighting research, GE, Sylvania, 1984 LA Olympics
1/ Magnetic ballasts are reliabile but poor efficiency, electronic more efficient but costly.
2/ Use of the old FL tubes has been suplanted by LED replacement fixtures, and basllasts.
3/ Ballast quality can be excellet (made in EU) or bad (China)
4/ LED quality is similaryly quite variable
5/ the so called LED fluroescent tube substutes are as noted low output.
6/ In Paris and USA we removed all old FL tubes/ballast/fixtures
We replaced with Sylvania Helios gas cooled filament LED with 200 lumen/watt efficicy.
https://www.sylvania-lighting.com/media/6737/sylvania-helios-led-brochure.pdfhttps://www.sylvania-lighting.com/en-int/news/items/helios-led-technology/Any colotr temp and infinite life!
7/ Ballasts we used are the fine Italian TCI with slectable current and 0-10V or pushbutton on/off/dimming.
https://www.tci.it/en/products/electronic-ballasts/8/ A colleague used CREE LED strips to make DIY fixtures with reflector and ballast.
Hope this is useful!
Bon chance !
HAVE A ABSOLUTELY FANTASTIC DAY!
Jon
