Author Topic: Lets see your Nixie Tube equipment  (Read 132150 times)
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
Re: Lets see your Nixie Tube equipment
« Reply #375 on: May 29, 2019, 01:15:45 am »
he pulls out what's in the second picture.  ARE YOU KIDDING ME ?  The service manual for one of the most obscure pieces of equipment.  It looked like it
never was opened.  I could not, in good conscience, not give the Vidar a chance to be functional.  ::)
That's worth scanning to PDF for the archives for sure. :)
Offline bob91343
« Reply #376 on: May 29, 2019, 03:26:25 am »
This is my EI3000 voltmeter.  Rated 0.01% on dc and 0.1% on ac, still works great.
The following users thanked this post: edavid, Cubdriver
Online tggzzz
« Reply #377 on: May 29, 2019, 08:44:57 am »
Yea i have a soft spot for nixies... so fresh into the lab... a Solartron LM1619 volt meter and the nixies are not the only tubes in it
oh and 1KV on unshrouded banana sockets? i guess things was different back then! :-+ :-DD
I'll raise you dekatrons plus 200-500V output plus finger accessible plus school equipment... With the EHT switched on, touching the GM socket's centre conductor with a finger causes it to count.
No, you don't feel a shock since the output impedance is ~5Mohm :)
« Last Edit: May 29, 2019, 08:46:54 am by tggzzz »
The following users thanked this post: richfiles, bitseeker
Offline Enigma-man
« Reply #378 on: May 30, 2019, 02:40:02 am »
Wow ! Dekatrons. My favourite next to Nixies.
I sure wish I could find a schematic for a low frequency counter because I have more than a dozen Dekatrons and have
no intention to make shitty Dekatron spinners out of therm.  ;D
# bob91343... Very nice to see some rare pieces of equipment.
« Last Edit: May 30, 2019, 02:42:58 am by Enigma-man »
Offline Enigma-man
« Reply #379 on: May 30, 2019, 02:47:33 am »
Vidar 500 Voltmeter revisited.
I got the Vidar 500 fixed last night and here are two pix showing it measuring voltage compared to my Dana 5330
and frequency compared to the HP 5340.
The Vidar had several issues, but no collection of Germanium transistors, resistors and caps was going to defeat me.
It works and that was my goal.  The only one left to fix is the Systron Donner 1032 and it will be work again.
Online tggzzz
« Reply #380 on: May 30, 2019, 07:59:33 am »
Back in February this year, my good buddy gave me a Weston Standard Cell.  Up until the mid 90's the Weston Cells were the worldwide voltage standard.
on the net.  A new Weston Cell was 1.01830 volts.  The cell is only supposed to be guaranteed accurate for a number of years but I have read some are still good after many decades.
There are two types of Weston standard cell: saturated and unsaturated, with different voltages and tempco and lifetimes.
Saturated cells are stable for decades (I have one from 1949), have a 40uV/C tempco, are fragile, so are only used in labs. Your image shows one.
Unsaturated cells have lower tempco, are more robust, have a shorter lifetime, and were used in portable equipment.
Offline bitseeker
« Reply #381 on: May 30, 2019, 05:10:21 pm »
The Vidar lives! :-+
Offline schmitt trigger
  • Country: mx
« Reply #382 on: May 30, 2019, 05:34:54 pm »
My ultimate idiot box: Nixies, Dekatron, Neon lamps, and a Magic eye. All counting in random sequences.
All synchronized with beeps.
A real mind-relaxing apparatus, very effective for dealing with headaches caused by stubborn people.
The following users thanked this post: edavid, VK5RC, bitseeker, xavier60
Offline bitseeker
« Reply #383 on: May 30, 2019, 06:58:03 pm »
Awesome. A video demo is requisite for this curiosity. ^-^
  • Country: mx
« Reply #384 on: May 30, 2019, 11:57:35 pm »
I would love to share a video, but EEVBLOG doesn’t allow uploading videos?
BTW; I have called this contraption “Der sinnlose Zähler”. The senseless counter. Although I ignore whether my German language skills are good enough and this name makes any sense.
Or perhaps “The ultimate idiot box”, again in German.
Perhaps some native German speakers may suggest a catchy name? That would be appreciated.
« Last Edit: May 31, 2019, 12:02:42 am by schmitt trigger »
Offline bitseeker
« Reply #385 on: May 31, 2019, 01:19:33 am »
No problem. Video goes on YouTube. Link to video goes into EEVblog forum post.
Offline greytop
« Reply #386 on: September 13, 2019, 09:45:50 am »
I have just dug a Daystrom Schlumberger 1291 out, tried it 30+ years ago, functioned then. Must try it again
Offline mikeinkcmo
« Reply #387 on: September 29, 2019, 12:21:10 pm »
I've scrolled through all the pages and haven't seen an HP-312 selective volt meter.
I also have a 5245M counter that I've had for quite a while.
The following users thanked this post: SLJ, edavid, bitseeker, Cubdriver
Offline Johnny10
« Reply #388 on: September 29, 2019, 01:45:54 pm »
Now those are cool !
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
Offline scopeman
« Reply #389 on: February 08, 2020, 09:08:49 pm »
Wow I used to use a HP312 when I worked at Western Union in the late 70's before we replaced them with HP3586's.
Sam
W3OHM
W3OHM
Offline video99
Re: Lets see your Nixie Tube equipment Fluke 8375A
« Reply #390 on: March 30, 2020, 10:01:46 pm »
Hello
A while back you mentioned a Fluke 8375A mnultimeter.  I'm looking at one of these, there seems to be a power supply problem.  I'm sure there should be a regulated output of about 9V from Q6 (the one with the heatsink) but I'm only seeing about 0.9V from there.  I've checked pretty much every component on the PSU and replaced all bad ones but to no avail.  I don't suppose you have a schematic for the PSU do you?  I'm working blind and with the present crisis, finances are tight beyond belief so I can't really buy a manual for a unit which is more of a curiosity than a useful piece of test kit.  I would just like to get it to run to show off the display if I can.  At the m,oment the machine appears dead though the high voltage for the tubes is present.
Thanks for any help if you can.
All the best,
  Colin
colin@video99.co.uk
youtube.com/video99couk
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #391 on: March 31, 2020, 07:48:46 am »
Colin, I *think* I have a manual for an 8375A lurking about somewhere here (I have an 8375A in my to-be-looked-at pile, and am fairly certain that I got a hard copy manual for it).  I'll try to find some time to dig for it in the next day or three, and offer what insight I can if it turns up.
-Pat
Offline Martian Tech
« Reply #392 on: November 07, 2021, 06:31:24 am »
16 pages and no Heathkit?  :D
Offline bob91343
« Reply #393 on: November 07, 2021, 05:12:49 pm »
EI 3000
Offline Electro Fan
« Reply #394 on: November 08, 2021, 04:29:22 pm »
Here is a HP 5327B displaying a 49,152,000 Hz signal from a Leo Bodnar GPSDO while taking a 10 MHz reference clock signal from a BG7TBL GPSDO.  When I first got the 5327B several years ago it was missing the 8th tube and an IC so when I found a source I figured I'd go for some spares.  The 5327B seems pretty accurate and it is just plain fun to look at.
Offline Johnny10
« Reply #395 on: November 08, 2021, 05:03:05 pm »
You've got to stock up just in case.
Offline Electro Fan
« Reply #396 on: November 08, 2021, 07:05:36 pm »
This is what I’m thinking.  :)
Offline Dave Wise
« Reply #397 on: April 29, 2024, 03:10:55 pm »
My Fluke 8100B 12000-count bench DMM with the very interesting Recirculating Remainder ADC.  (Volts and ohms, no amps.)  It's hard to get a good picture of the display due to multiplexing.
Offline Dave Wise
« Reply #398 on: April 29, 2024, 03:13:57 pm »
One of my HP 740B DC Voltage Standard/Differential Voltmeters.  On its side for troubleshooting.  The Nixie tubes display the knob positions, they don't dynamically change with input voltage.  So just an electronic version of the mechanical digit wheels on a Fluke differential voltmeter.
Offline Dave Wise
« Reply #399 on: April 29, 2024, 03:38:11 pm »
My Monsanto model 2000 Digital Voltmeter.  DC Volts only.  Easy on the eyes 20000-count non-multiplexed display required many many RTL integrated circuits for counters and latches.  As far as I can tell, this is Monsanto's only DVM ever.  I never found any advertisements for it, just an oblique mention of "a digital voltmeter" in an article from Chemical Engineering News January 1966 edition... which I can't find anymore.  Gift from the late noted Tektronix collector Stan Griffiths.
It uses a single-slope converter with an electromechanical "Synchroverter" chopper.  Communication across Guard is two pulse transformers with interesting signal timing.  The automatic polarity switching is awkward and went through significant mods that appear to be from the factory, and it was still flawed - to measure a guarded negative voltage you had to manually connect GUARD to the IN terminal instead of the COMMON terminal.  I fixed that by changing the circuit yet again.  Other changes I made ended up inserting two microcontrollers to correct some timing glitches.  It's kind of a Frankenstein but it works.
