After all the positive reviews for it I thought I'd better get myself a TS100. Up to now it all seems very good.
There's one small exception to this and I could use some advice. The PSU I am using is a universal laptop job set to 20V and seems to be nice and stable. But it's not earthed, and there is AC leakage onto the tip of the iron at 120V (more or less the supply here). So I earthed it, using a wire from the earth connector on the iron to the earth pin on the mains plug. When I do that the iron's temperature (as measured by itself) goes haywire, swinging wildly from 200ishºC to nearly 400. I doubt it is actually doing that as the change is far too rapid so I think the earthing is screwing up the thermocouple. Disconnect the lead and it settles down to a nice steady 300ºC again.
My best solution is, I think, to find a more suitable supply. But nevertheless I'd like to understand what's going on. Does anyone have an explanation?
