Author Topic: Replacement Soldering Iron/Tips for ZD-937?  (Read 4882 times)
Offline leifTopic starter
« on: May 12, 2017, 11:00:53 pm »
I've just had to find out that after changing connectors on my cheap Hakko soldering iron clone that it won't work with my ZD-937 station because Hakko uses a thermistor to measure tip temperature and my ZD-937 station expects a thermocouple. The tip gets hot but the station signals error because it can't sense the temperature.
Can anybody give me a suggestion where to find cheap spare tips or a reasonable priced spare soldering iron? The typical Chinese places are flooded with Hakko-stuff but my ZD-937 with 4-pin connector and 5.9mm diameter heating element seems to be a dead end?
Any suggestions?
Leif
Offline Shock
Re: Replacement Soldering Iron/Tips for ZD-937?
« Reply #1 on: May 13, 2017, 03:06:07 am »
Offline OZ1LQB
« Last Edit: May 13, 2017, 02:46:50 pm by OZ1LQB »
Offline KL27x
« Reply #3 on: May 16, 2017, 06:26:13 am »
This company is in Florida. But for reference:
http://www.mpja.com/ZD-929C-Solder-Station/products/460/
dirt... cheap...
I used this station/iron for quite a few years, myself. Cheap tips, cheap irons, terrible tip selection. It's too bad you can't use the Hakko.
I'm not fresh on the difference between a thermocouple and a thermistor sensor, but perhaps you can interject an opamp to tweak the gain? Once you get a replacement iron, anyhow, you can record the voltage at various temps to map it out and then... well, hah, yeah, this is a huge waste of time... one that I did at one point in making a DIY temp controlled station.
« Last Edit: May 16, 2017, 06:35:32 am by KL27x »
Offline dimkasta
  • Country: gr
« Reply #4 on: May 17, 2017, 09:04:39 am »
The usual Chinese suspects should be flooded with spare parts for that series.
I have the older versions and I can find tips and parts very easily and cheaply, both locally and on the internet
