Careful With That coAx, Eugene.
A zip tie gun will easily damage coax cables. A company I worked for in the 1980:ies installed several hundred meters of RGB coax in a building. All of it had to be replaced due to ghosting video due to damaged coax (impedance changes where zip ties deformed the coax).
