I feel very lucky today!Today, I went to the Home Depot to pick up Vinyl tubes for my project. I thought to stop by Electrical Department to see if they have anything new/cool. I saw this bright orange Klein Tools MM2000 multi-meter sitting on the shelf and though to check it out. The specs look reasonable. It is more for electrical work not electronic. This is because the missing mV selection. It may not be a problem if you don’t need resolution in mV range. It got 4,000 counts, CATIII 1,000V, true RMS, LowZ, uA, temperature, capacitance, Hz, Duty Cycle and more. It comes with very sharp probes, alligator clips and thermocouple probe (see pictures below). Guess the price tag? It listed $59.88! I thought to myself… Wow that is a good price. Klein Tools is a well know company for electricians. The company has been around since 1857. They made good high quality hand tools and meters for professional electricians. I think it is a US company (correct me if I’m wrong). Oh… and this particular model of multi-meter is made in Korea! No way… finally something doesn’t make in China. So I decided to buy one just to check it out. I don’t really need another meter, but why not for this price.
Went to the cashier to pay and it rang up for $99.98! What! I’m not paying for this. There is something wrong. I marked with $59.88 on the shelf and there is nothing else says $99.98 on the entire shelf. Something is majorly wrong here! It turns out this is a brand new item that just got put up by the night crew last night. I’m not sure this it is a new item to the Home Depot or new product. But they screwed up. This is the price for the other model MM1000 which currently they don’t have. Don’t ask me how that happened because I don’t care. It said $59.88 so I’m only going to pay $59.88. After spoke to the manager they agreed to adjust the price for me. That is why I feel so lucky.
Just because of that I think I’ll give it back to this community and give the Klein Tools MM2000 a review here. Another thing is no one has talk about Klein Tools in here before so here it is.
This is the receipt with $40.10 off! I blacked out some information. Don’t want anyone at Home Depot to get in troubles. The packaging looks okay. I love that they have the features and specs clearly labeled. My Fluke 179 box doesn’t have this much info.This is the unit with white backlight on. It has very nice big font and unique bar graph on the bottom. Here is the unit on Ohm measurement. Before reading the manual I was like what the heck is “Apo” and “AT”. Can anyone guess?
“Apo” = Auto power off
“AT” = Auto rangeHere is the back of the unit. The tilting bail is a hard plastic and fold out at about the same degree as my Fluke 87V.“Don’t turn it on – take it apart!” Of course, taking CATIII meter apart I’m using CATII rating screw driver! The holster is a bi..h to pull out. I was very close to pull out my hammer.
Here is the back without the holster. You can see the “Made in Korea”.Remove one metal threaded insert to get to the battery and fuses compartment. Look at those nice two big HRC fuses. It uses 2 AAA batteries!I almost rip this thing apart without removing the screw underneath the battery. Here it is with 5 self-tapping screws they are easily come apart.Here are some engineering porn photos Look like they use mostly prime spec parts. Lots of potentiometers.Bad hand solder job on those shunt resistors. Left over flux.Back cover.Here you can see some blast protection notches.Close up of sense resistors and bad solder joints.More electronic side. Nice gold plated PCB layout.Here is the accessories that come with it.Nice sharp probes with CATIII 1,000V 10A rating.Alligator clips with CATIII 1,000V rating.Thermocouple probe (not sure what is the range of this particular probe).Nice solid jacksHere is the voltage comparison with my Fluke 87V. It looks good to me. The digit is bigger, the backlight is brighter and the unit is smaller and light than the Fluke 87V. Of course, the accuracy is not as good as Fluke 87V.Here is the manual and specs…phew that is a lot of work. I’ll come back some other time to review the technical aspect of this meter. Or if you have any quick questions that I can answer about this meter please feel free to post it here.
