Author Topic: JBC DR560-A desoldering tool heating element  (Read 1203 times)
Offline gaminnTopic starter
« on: July 18, 2024, 06:38:27 am »
after 27 hours operating time and 201 hours sleep time the heating element of JBC DR560-A doesn't work anymore (open-circuit). Most time I set 400°C operating temperature and 260°C sleep temperature.
Anyone with DR560-A: how long your heating element lasts?
Not only DR560-A is quite expensive, it also seems that operating it is expensive, as the heating element is around 130 EUR.
I noticed e.g. Hakko FR301-03/P heating elements costs only half of the JBC's one. Is there anyone with this desoldering tool to compare the lifetime of the heating elements?
Online thm_w
  • Non-expert
Re: JBC DR560-A desoldering tool heating element
« Reply #1 on: July 18, 2024, 09:01:00 pm »
See if they'll take it back under warranty.
The heating element is just a normal JBC cartridge, so I would expect it to last a while, rarely reported here that the heaters fail.
Though the thermal mass is a bit higher so the heater could be stressed more.
http://adgd.ru/2020/02/16/jbc-dr560-a/
« Reply #2 on: July 19, 2024, 07:57:55 pm »
The heating element was almost 10 years old (but only with 27 hours operating time). I sent all the info to my distributor, they contacted JBC. We will see what the conclusion will be, if any. Meanwhile I ordered 2 heating elements and other consumables for DR560. For that price normal people buy complete soldering stations! :D
« Last Edit: July 19, 2024, 08:01:44 pm by gaminn »
Offline KG7AMV
  • Rhine_Labs
    • My Personal Blog
« Reply #3 on: July 22, 2024, 06:56:04 pm »
Yea, that's the issue with JBC expensive, but should have lasted more then 27 hours.
Offline Arts
« Reply #4 on: July 25, 2024, 09:21:42 pm »
I have a DS 5300 desoldering station that uses the DR 5600 iron. This iron was the forerunner to your DR 560.
I have been using this machine daily for 30+ years, and have never changed the heating element. In fact, I am still using the original 5600-003 tip that came with the unit for most of the work I do. I cannot imagine a JBC heater failing at such low hours, regardless of age.  :-//
