Author Topic: Low end soldering station tip quality...  (Read 8820 times)
Offline crispy_tofu
Re: Low end soldering station tip quality...
« Reply #25 on: September 22, 2015, 02:42:53 am »
nanofrog, are you really sure about the flux coating? I've had brass wool from Weller and Ersa (genuine stuff) and never noticed any  :-//
I recall reading that somewhere.
Yes, Dave talks about having a flux coating on the wool in his Soldering Tutorial Part 1 (EEVBlog #180) at about 4:00.
Offline tooki
« Reply #26 on: September 27, 2015, 11:09:47 pm »
I'm not even 100% sure that fully dried rosin does much as a flux.
What exactly do you think the core of rosin-core solder is made of, then?!? If it relied on solvents, solder would have an awfully short shelf life...
Offline KL27x
« Reply #27 on: September 27, 2015, 11:18:45 pm »
I suppose so. The main active ingredients in flux are acids (abetic acid in rosin, IIRC), and I figured they would work better when dissolved in water/solvent. Maybe I was thinking about it all wrong.
« Last Edit: September 27, 2015, 11:21:30 pm by KL27x »
Offline continuo
« Reply #28 on: September 28, 2015, 08:45:56 am »
FWIW: I've just opened up a brand new Weller "T0051384099" dry cleaning wool (brass) and it's definitely not flux covered. It's just plain metal wool, nothing more.
« Last Edit: September 28, 2015, 09:35:24 am by continuo »
