So that would suggest your first one was not reversed either, and so that's not what blew it up. I thought it odd that a reversed polarity would cause that much damage, anyway.I suspect you had another component fail short.
The markings on the PSU board are reversed.
Quote from: AstutePauciloquent on January 18, 2024, 11:44:40 pmThe markings on the PSU board are reversed.The + and - markings on the PSU board near the 24VDC connector are for the through holes, not for the connector pins.
Quote from: Seb71 on January 19, 2024, 10:02:25 pmQuote from: AstutePauciloquent on January 18, 2024, 11:44:40 pmThe markings on the PSU board are reversed.The + and - markings on the PSU board near the 24VDC connector are for the through holes, not for the connector pins.Yes I see, it makes it very confusing. I've drawn my own - and + on the board for future reference.
