Hi all!
I've just picked up a TS100 soldering iron - I'm still amazed at how awesome this is for such a cheap bit of kit!
I'm afflicted by a mild essential tremor - not really anything that gives me any grief in my daily life but it makes soldering a nightmare. When you consider how far back you hold an iron from a tip, a mild tremor at the hand can turn into a massive swing at the tip of the iron!
The TS100 helps out here a bit with a shorter distance from handle to tip, as well as the ability to hold the handle much lower down, but I still struggle with anything more than standard THT.
If I'm able to rest my wrist on a surface, I pretty much have full control of whatever I'm holding. If I could hold the iron more like a pen, I reckon I could manage to solder SMD. I thought I read that a sheath for exactly this exists.
I've looked around, but either this doesn't exist, or I'm not using the correct search terms. Does anyone know if something like what I'm describing exists?
Thanks in advance!
