Author Topic: Kitchen scale  (Read 10667 times)
Offline ipmanTopic starter
Kitchen scale
« on: July 04, 2011, 05:01:27 pm »
My mother complained about her kitchen scale not weighting anymore.
Of course, it was "take it apart" time.
Altough I did know that this scale was refurbished before was sold, what I found inside was beyond my imagination. A double sided PCB soldered only on one side, there were cold solder joints everywhere, some of them had even 80ohms!
This is a Laica scale, italian brand, but i doubt that this was manufactured anywhere in Europe.
I've photographed only the PCB, which was the worst, but the screws were not tight, some broken, a really nasty job ... I wonder how this ever worked.
Wife hates words like Fluke, Ersa ...
Offline ndictu
  • Country: sk
Re: Kitchen scale
« Reply #1 on: July 04, 2011, 06:06:43 pm »
Hahaha, that's is amazing. Did you manage to fix it?
Also, why are the components on the wrong side, doesn't it fit the right way or what? The resistors should if that little DIP does, maybe the caps are too big? Or maybe they just didn't understand how to put it on? :)
Offline norEL
  • Country: no
Re: Kitchen scale
« Reply #2 on: July 04, 2011, 08:28:34 pm »
This looks really bad!!  :o Think I can say that I did a better work the first time I tried a soldering iron than the person that have done this "job". haha..
Offline Kibi
Re: Kitchen scale
« Reply #3 on: July 04, 2011, 08:41:05 pm »
I am lost for words. Simply amazing!  :)
Re: Kitchen scale
« Reply #4 on: July 05, 2011, 05:02:25 am »
Yes, i fixed it. The white and green wire had cold joints, around 80ohm each.
Of course, i cleaned the old solder on most joints and this time soldered them as they should be.
I cannot find the reason why they put the components like this. There was not enough room to fit the caps upright, but there was plenty to fit them to correct side.
All components were measured and they were inside the tolerances, even caps had they ESR in normal range. I did not expect that.
Offline EEVblog
Re: Kitchen scale
« Reply #5 on: July 05, 2011, 09:37:07 am »
What a shocker!  :o
Dave.
Offline saturation
  • Doveryai, no proveryai
    • NIST
Re: Kitchen scale
« Reply #6 on: July 05, 2011, 02:21:48 pm »
Wow, one of the worst I've seen, much worse than anything I've bought.  Doesn't it have a 'made in' anywhere?
Battery operated scales are far more prolific today, but old style analog weight based scales or even spring scales are accurate enough for most anything a consumer uses.  The only time I've seen electronics truly be of value is replacing a Mettler quality balance, because precision weights are very expensive, making an electronic version not only is cost effective, made correctly its superior due to near zero maintenance beyond calibration.
« Last Edit: July 05, 2011, 02:27:13 pm by saturation »
Best Wishes,
 Saturation
Re: Kitchen scale
« Reply #7 on: July 05, 2011, 04:02:02 pm »
No, there is no indication about where it was manufacured. But as usual I suspect a country whose name starts with C and end with A  ;)
It's usefull because it can measure grams. Yeast in a home-made bread must be between 3 and 7 grams, so it's more usefull than analog scales which cannot measure with such resolution. Compared to another similar scale, indications are the same and the bread made accordingly is soooo ... good.
Online Zero999
  • 0999
Re: Kitchen scale
« Reply #8 on: July 05, 2011, 04:27:41 pm »
How do you know if it's accurate?
It may be a couple of grams out.
Here's how I'd test it. take an empty syringe, put it on the scales and set them to zero. Fill the syringe with a known quantity of water and weight it again. 1ml of water weighs exactly 1g at room temperature and atmospheric pressure and a medical grade syringe should be more than accurate enough for what you need.
Offline Semantics
Re: Kitchen scale
« Reply #9 on: July 05, 2011, 04:31:25 pm »
Tsk tsk, Canada.  ;)
I'm guilty of picking up stuff from Deal Extreme and it's always scary to open it up and see the craftsmanship. That some of these things even work at all I pretty much call it all a miracle. Gotta hand it to China, though, that they're pushing the limits of non-manufacturability. I find it fascinating how badly things can be built, ignoring any IPC class of work, and still sort of function.
Offline sacherjj
Re: Kitchen scale
« Reply #10 on: July 05, 2011, 04:33:37 pm »
Kitchen scales don't need to be terribly accurate, but they must be electronic.  Once you have switched to cooking by weight instead of by measure, you life gets very easy.  The secret is because of the Zero tare, this is really hard with non-digital scales.
Put bowl on scale.  Zero tare.
Add first ingredient, until weight is correct.  Zero tare.
Add second ingredient, until weight is correct.  Zero tare.
etc, until done.  Mix.
This makes cooking SO much faster and you don't mess up all those measuring cups.  This is the reason I have 2 digital scales for the kitchen.  (But I'm the odd husband who loves cooking and might want to be a chef if the pay was any where near what I make as a programmer.)
Re: Kitchen scale
« Reply #11 on: July 05, 2011, 04:41:03 pm »
Cooking for engineer needs digital scales. Numbers are everything, I recon.
I understood breadmaking by numbers and ratios. Guaranteed to work, and results are quite consistent.
@Hero99: yes, the scale has an error more than 1 gram at 3 grams measured. But still, you cannot measure that resolution with a (quite cheap) analog scale. And, afther that, tare function cannot be beaten.
@Semantics: ok, I forgot about Canada. But I doubt they have such industry. A Canadian made scale under an Italian brand sold cheap in Romania? Very unlikely.
Online Zero999
  • 0999
Re: Kitchen scale
« Reply #12 on: July 05, 2011, 05:09:02 pm »
Do you know what sort of accuracy are you getting? Have you tested it?
Re: Kitchen scale
« Reply #13 on: July 05, 2011, 06:54:36 pm »
Sort of.
I've put on it the content of a yeast bag, weighted by the producers. They claimed 7 grams, the scale read 7 grams. I am fine with that, I don't need sub-gram precision, even a 1-2 gram accuracy is good enough, will not make much difference in bread-making.
Offline Neilm
Re: Kitchen scale
« Reply #14 on: July 05, 2011, 07:05:16 pm »
Shame - we could have sent them a link to EEVBlog #183
Neil
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline saturation
    • NIST
Re: Kitchen scale
« Reply #15 on: July 06, 2011, 09:48:11 am »
Tare makes sense that way, an engineer minded person can easily choose a proper scale too, with resolution and accuracy to fit the need.  Clearly, chemistry is nearly all in weights.
I was thinking more of its use in dieters and diabetics, were weight = calories, but making easily reproducible meals has its appeal.
Best Wishes,
 Saturation
Online Zero999
  • 0999
Re: Kitchen scale
« Reply #16 on: July 06, 2011, 05:47:39 pm »
Sort of.
That's amazing given the poor build quality, perhaps they haven't skimped on the strain gauge, just on the assembly?
Re: Kitchen scale
« Reply #17 on: July 06, 2011, 08:14:39 pm »
Strain gauge is for sure produced as a whole by others. It is sealed, wires are stuck with some goo, looks like a decent quality. It works just fine. (Sorry, no pictures).
I did not had access to weight standards, so I improvised weighting things and comparing with their specified weight on package, at the same time comparing with a similar scale and that worked like a charm: both indicated same weight.
alm
  • Guest
Re: Kitchen scale
« Reply #18 on: July 06, 2011, 08:27:50 pm »
Weight is almost exclusively used for solids in chemistry, i.e. for weighing them just before they're dissolved. Weight also get tricky for small volumes, try using a balance and spoon to add 1ul. Just weighing 1mg gets interesting, any airflow will screw up your measurement. Pouring doesn't work at those volumes, and if you use a temporary container (like weighing paper), 90% of it would stick to the container.
For cooking it's different since volumes are large and required accuracy is low.
Offline saturation
    • NIST
Re: Kitchen scale
« Reply #19 on: July 06, 2011, 10:08:36 pm »
Yes, clearly chemistry is also in various liquids and gases, but meant just for the purpose of the gross measurements in food.  I'm not sure if cooking by the numbers will appeal to chefs, but its a wonder why its not used often if precise repetition is preferred?
For tiny quantities, analytical techniques appear.  A simple one is remeasuring the temporary container for residuals weight after emptying.  At that resolution, scales require special mounts and tables to be set near absolute flatness, shock absorbancy and chambered against airflow.  Lucikly we don't get so tiny, unless there are gourmet ants!
Best Wishes,
 Saturation
Re: Kitchen scale
« Reply #20 on: July 07, 2011, 10:04:40 am »
I am an engineer, so I understand numbers easier than chef do understand receipes.
Even measuring the same weight with allmost-a-gram precision, there are many other factor which will make a food not exactly a clone of the previous one. In breadmaking, flour can differ, temperature is not the same, when you put "a teaspoon of sugar" some crystals can fall and feed better the yeast in one part of the bread, making it inequal, and so on.
We, technicians and engineers (politically corect!) call this "tolerance"  :)
Offline saturation
    • NIST
Re: Kitchen scale
« Reply #21 on: July 07, 2011, 11:23:33 am »
Yes, and the materials used, the ingredients, pots, and cooking heat, can have much variability, so precise measurements doesn't guarantee uniformity or the desired outcome, however that's defined.  Luckily, processed ingredients rather than raw or fresh material, is more homogenous and works better.
Military, fast foods, and cafeteria cooks do it by the numbers or measures, and their cooking has a reputation of its own.
Chefs taste and examine the ingredients purchased to insure it has the characteristics they need, if its less or more than expected, they adjust the recipe as needed,  most sample the effects of cooking and adjust in the pot too.   So in the end, chef style is tied to the chef's palate, and the recipe is a guide not the law.
Best Wishes,
 Saturation
