I'm thinking of buying a Weller W61 soldering iron - it's one of those where you change the temperature by changing the tip. It comes with a 370C (700F) 2.4mm chisel tip. 370C is the same as the old Magnastat number 7 tip I believe. I would be using the iron for repairing old through-hole stuff with leaded solder (60's-70's electronic organs, 70's-80's analog synths, old pinball machines etc.) and building new through-hole stuff mainly with leaded solder (will get into SMD later and perhaps into lead-free, too, but I'll get another tool for that stuff).
Now my question is: is that tip the correct for my planned work? Or should I buy a tip with a lower temperature? What type of a tip people used with their old Magnastat Weller's for leaded through-hole stuff, tip number 6 or 7?
Thanks in advance for any insight into this!
