Apart the problem Dave reported, what are the other problems? Could someone make a summing up?
Tricky question , but it was expected to be an such, when it comes from a Greek .
I will not fall in the trap , by making a summing up, with opinions build by others.
I know well that PetrosA , one man that I do trust his opinion, he has one , and works daily with it ,
it is his main DMM , and he is very happy, so far with it.
And I will just speculate , that I will have the same possitive experiances that PetrosA had,
due the fact, that I do properly use the range switch, in everything that I own.
Some people probably, they can not distinguish the difference between of something that called as " True problem ",
in comparison with something that called as "Potential problem".
Even so this devices are designed by scientists and top Class Electronics Engineers,
my role is to point issues that I will found as user, by working with it in the field.
And so far, no one had reported any issues that effects the measurements or safety.
And as last I will say that I am denying to accept , the story of one unit that indicates to was out of calibration,
as an reason for an front page.
I would be less skeptic about the range switch issue that Dave find out,
mostly because the range switch , it is something important.
Many healthy DMM's find their way to the trash bin , due a failing range switch.
About my own experiences with it , I will post them In a month from now,
Agilent will be the first who will read my own summing up.
My own decision is to not interfere at all , at any buying decisions of any one,
when it is related to opinions about build quality.
I am not a scientist or a top Class Electronics Engineer.
