Author Topic: Multimeter Amprobe broken help  (Read 4345 times)
Offline funnelTopic starter
« on: November 11, 2013, 05:02:31 pm »
I need help figuring out what is wrong with my multimeter. It's an Amprobe 240. I don't know how it happened exatcly but the knob was acting weird for a few weeks with the screen going on and off when selecting the DC function. You can see in the attached picture the burnt trace I cleaned but didn't help. Without measuring anything the multimeter is showing 1.052 V DC, 25.86 kOhm, and 144.1 uA. I also get wrong readings for resistors using the relative button.
Anybody knows how to find out what's wrong? Can I fix it or is the main chip toast?
Thanks.
Offline retiredcaps
Re: Multimeter Amprobe broken help
« Reply #1 on: November 11, 2013, 05:26:42 pm »
Check the PTC right by the volt jack.  It should be around 1 kohm.
Check your burnt trace to make sure it is not conductive as per
http://mrmodemhead.com/blog/ideal-carbon-footprint/
« Reply #2 on: November 11, 2013, 05:51:59 pm »
Wow. Thank you. I scraped the carbon with an exacto knife and now it works perfectly. Thank you.
Offline retiredcaps
« Reply #3 on: November 11, 2013, 06:45:38 pm »
I'm glad you got it working, but all credit/kudo should go to modemhead for taking the time to document and photograph the repair for everyone's benefit.
