Author Topic: FNIRSI DWS-200 200W doubt  (Read 826 times)
Offline Jon.CTopic starter
  • Country: ad
« on: September 12, 2024, 12:11:17 pm »
Hello
Has anyone tested whether the original JBC tips work on the FNIRSI DWS-200 200W
both the 245 and 210 tips
since the JBC ones are 120W and this one is 200
Thanks!!
Online thm_w
  • Non-expert
Re: FNIRSI DWS-200 200W doubt
« Reply #1 on: September 12, 2024, 10:52:55 pm »
https://www.fnirsi.com/products/dws-200
Wrong forum, asked to move: https://www.eevblog.com/forum/reviews/
Yes T245 tips and T210 tips will work with it. Assuming you get both handpieces.
Handpiece uses a 5-pin circular connector instead of the official JBC 6 pin. But these are readily available on aliexpress.
200W is just what they are claiming the internal power supply is rated to. T245, maybe they will hit 160W or so, depending on their supply voltage and internal power limiting code. T245 tip is around 2.5 ohm so theoretically ~230W is achievable with 24V DC.
Though I would not touch this station until we can verify that the tip is properly grounded, after the mess that Aixun left.
The following users thanked this post: Jon.C
