Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Other Equipment & Products
IDC CONNECTOR WITH FLAT BLADE PINS
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: IDC CONNECTOR WITH FLAT BLADE PINS (Read 1803 times)
paulc
Contributor
Country:
on:
September 05, 2015, 11:01:34 am »
Please look at the attached pictures.
I need help finding the part number or at least manufacturer name for the connector on the flat cable.
The equipment is from GERMANY so probably it is a german or european manufacturer.
Thanks.
Logged
jitter
Frequent Contributor
Country:
Re: IDC CONNECTOR WITH FLAT BLADE PINS
Reply #1 on:
September 05, 2015, 11:08:00 am »
Oh yeah, these ring a bell... I've seen them at work.
Molex Picoflex, perhaps?
Last Edit: September 05, 2015, 11:12:15 am by jitter
Logged
ovnr
Country:
Lurker
Reply #2 on:
September 05, 2015, 11:10:33 am »
Looks like a
Molex Picoflex PF-50 90327
. Double-check the pin pitch first, though.
Also, here's the
mating connector
Logged
jitter
Country:
Reply #3 on:
September 05, 2015, 11:12:59 am »
Hah, you beat my edit...
Logged
bktemp
Super Contributor
Country:
Reply #4 on:
September 05, 2015, 11:23:39 am »
Lumberg Micromodul:
http://www.lumberg.de/main/common/serie.asp?ser=030&cat=1&lang=deu
Logged
paulc
Contributor
Country:
Reply #5 on:
September 05, 2015, 11:24:11 am »
The MOLEX PICOFLEX is exactly what I was looking for.
Many thanks,
Paul
Last Edit: September 05, 2015, 04:54:46 pm by paulc
Logged
Quarlo Klobrigney
Country:
This Space For Rent
Reply #6 on:
September 05, 2015, 11:24:54 am »
https://www.samtec.com/connectors/rugged-power.aspx
Logged
Voltage does not flow, nor does voltage go.
paulc
Contributor
Country:
Reply #7 on:
September 05, 2015, 12:44:44 pm »
The SAMTEC connector is different from the one I was looking for.
Paul
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
