Author Topic: High Precision 10 V Reference - Analog Devices AD587KN + AD7535JN + 5x OP07CJ  (Read 7020 times)
Offline DC1MCTopic starter
This topic pertains to the $subject, low cost (10EUR) cards that were avalable from the ebay seller  smokeli.
https://www.ebay.de/itm/High-Precision-10-V-Reference-Analog-Devices-AD587JN-AD7535JN-5x-OP177/154410695222
[url=https://www.ebay.de/itm/High-Precision-10-V-Reference-Analog-Devices-AD587JN-AD7535JN-5x-OP07CJ/154410692288]https://www.ebay.de/itm/High-Precision-10-V-Reference-Analog-Devices-AD587JN-AD7535JN-5x-OP07CJ/154410692288[/url]
He also has on his alternate account, the matching connectors:
https://www.ebay.de/itm/96pol-Federleiste-Buchsenleiste-90-gewinkelt-3-reihig-female-ERNI-004516/124355155637
There are a number of variants, some of them had AD587KN, others AD587JN, personally have 2 with AD587KN.
The most important components are socketed and can be harvested "as-is", but the idea is to reverse the board and see if we can use it in the current configuration.
So enjoy the top/bottom pictures and the first blood power of a board.
Cheers,
DC1MC
« Last Edit: April 18, 2021, 12:25:36 pm by DC1MC »
The following users thanked this post: thm_w, syau
Intial examination:
The logic on the board is fully combinational, no pesky clocks or other noise inducing signals.
The value of the 16bit BCD inputs are latched via IC2 and IC3 (74HC573A Octal TransparentD-TypeLatchesWith 3-State Outputs) and displayed on the front 4 digit 7-segment display, via the decoder ICs 7-9 (HEF4511BT BCD to 7-segment latch decoder drivers).
Also the input values are entered in a BCD to binary converter EPROM IC14 (M27C1024 64KBx16 UV EPROM), the outputs go into IC15 (AD7535JN 14bit DAC with parallel inputs ) that uses as reference IC16 (AD587KJ or JN 10volts precision reference).
On the board are a large number of precision OP, either OP07 or OP177, some relays and a mystery EPROM, IC1 (M27C128 16KBx8).
On the front panel there are two 2 positions, non-retaining switch ( Ein - 0 - Ext ein) and (Aus - 0 - Setz), most likely switching the reference with some external one.
Recommended BCD switches:
https://www.ebay.de/itm/Kodierschalter-0-9-BCD-Codierschalter-Vorwahlschalter-Pushweelswitch-1-Stuck/312231336643
So much for now, lots of things TODO.
Power (before pinout):
+5V - Over C2 (Tested OK)
-15V - Over C4 (Not-tested!!!, polarity OK, actual value TBD).
+15V - Over C6 (Not-tested !!!, polarity OK, actual value TBD).
Fun (?!?) fact: in my board the line on the capacitor body signifies (-) but fortunately the correct polarity is printed on the PCB silk mask.
Offline Bad_Driver
The same BCD switches from Aliexpress, just ordered!
Still awaiting the boards ....  :box:
„Everything must be made as simple as possible. But not simpler.”
― Albert Einstein
Offline McBryce
     I have two of the boards and I've dumped the EPROMs. The BCDBIN (27C1024) has identical contents on both boards (as expected) and contain a lookup table. The mystery EPROM (27C128) is different on both boards. They are essentially blank (filled with &00 not &FF) except for a few bytes which are possibly some sort of addressing for the card? Binary files below.
McBryce.
« Last Edit: April 21, 2021, 07:22:45 am by McBryce »
Offline Bad_Driver
Interesting! Only 2 Bits difference. Let's see what the other board owners report.
btw: what are you using for the EPROM read-out? I do not have anything for this but it's never to late.
― Albert Einstein
Offline McBryce
My recommendation depends on how often you would use it. I have a Batronix BX48. It's bullet-proof and can program almost anything you throw at it, but it's relatively expensive. However, I use it almost daily as my main interest is vintage computer repair / restoration. For casual use there are much cheaper solutions, such as the TL-866 which I would also highly recommend.
McBryce.
https://www.batronix.com/versand/programmiergeraete/BX48/batego-II.html
https://www.ebay.de/itm/TL866A-Great-Speed-in-circuit-Programmer-USB-EPROM-EEPROM-FLASH-BIOS-AVR-AL-PIC/402699959557
Thanks everybody for your contribution, now the bit two tasks are waiting ;)
 - Connector pinout !!!
 - Analog part schematic, what are all the OP doing ?
If something's left in WE, I'll try the pinout, at least to start it.
 Cheers,
 DC1MC
Offline Bad_Driver
It's 40 years ago when I built my last EPROM programmer for a Z80 based OEM system (U880 in East Germany) and wrote the assembler code.
I think the 2nd one is enough for my needs. Thanks for the link! I ordered one but it takes time on the slow boat from china  :=\
First idea was that the code line is a serial number of the board but than I saw that the datas are at different addresses in both EPROMs.
Hope my boards arrive today but DHL is like the weather, the forecast is never correct.
« Last Edit: April 16, 2021, 08:03:12 am by Bad_Driver »
― Albert Einstein
Offline McBryce
 Cheers,
 DC1MC
I have already started on some of the pinout, but I still need to find out how the connector pins are normally numbered. There's no pin numbers on the physical connectors I have.
McBryce.
Offline Bad_Driver
― Albert Einstein
The following users thanked this post: DC1MC
Offline McBryce
I found the shorter version just for that connector. I'll use the numbering they supply here (1 to 32 with rows ABC).
McBryce.
The following users thanked this post: DC1MC, Bad_Driver
Offline Bad_Driver
DHL is better than expected. My boards arrived.
Attached first shots for your entertainment.
Seems to be a multilayer PCB with ground and power supply in the middle?
― Albert Einstein
Welcome to the (very exclusive) club   :-+ !!!
Let's make the roll call, who has the boards and read the topic still ?
Cheers,
DC1MC
The following users thanked this post: FransW
Offline McBryce
Cheers,
DC1MC
Me, but I didn't have enough time to look at the boards any further yet.
McBryce.
Offline Bad_Driver
Sorry it takes some time to start. Real life implications during f@%&ing shutdown with 3 kids at home
and full time job give me only short interrupts for my bench.  :--
(nach dreizehn Monaten zweifelt man immer mehr an der Fähigkeit unserer geilen Regierung)
Has someone ask the seller where the boards come from?
― Albert Einstein
Offline artag
Unfortunately, he doesn't ship to UK
Offline FransW
Waiting for my boards & connectors.
PE1CCN, Systems Engineering, HP, Philips, TEK, BRYMAN, Fluke, Keithley
Offline tggzzz
Fortunately, in my case - since I have some standards and don't need another :)
Offline McBryce
For those who are as anal OCD as I am, I made this sheet to help on pinout reverse engineering. The connector picture is of the mating connector, not the connector on the populated PCB.
McBryce.
« Last Edit: April 18, 2021, 11:04:57 am by McBryce »
The following users thanked this post: Bad_Driver
Offline Bad_Driver
It seems that all boards are sold. That‘s good because I couldn't suppress my wish to buy more boards.
― Albert Einstein
Offline McBryce
Not going to have much more time today, so here is my Pinout info for today.
McBryce.
McBryce.
Lets add something extra, maybe next time we can have some common editable format, let's kill all the low hanging fruits:
      A        B        C
01 xxxxxxx  xxxxxxx  xxxxxxx
02 xxxxxxx  xxxxxxx  xxxxxxx
03 xxxxxxx  xxxxxxx  xxxxxxx
04 xxxxxxx  xxxxxxx  xxxxxxx
05 xxxxxxx  xxxxxxx  xxxxxxx
06 xxxxxxx  xxxxxxx  xxxxxxx
07 xxxxxxx  xxxxxxx  xxxxxxx
08 xxxxxxx  xxxxxxx  xxxxxxx
09 xxxxxxx  xxxxxxx  xxxxxxx
10 xxxxxxx  xxxxxxx  xxxxxxx
11  -15V     -15V     -15V
12  -15VX    -15Vx    -15Vx  (IC20 - OP07)
13  +15V     +15V     +15V
14  +15VX    +15Vx    +15Vx  (IC20 - OP07)
15   GND      GND      GND
16   GND      GND      GND
17   +5V      +5V      +5V
18   +5V      +5V      +5V
19 xxxxxxx  xxxxxxx  xxxxxxx
20 xxxxxxx  xxxxxxx  xxxxxxx
21 xxxxxxx  xxxxxxx  xxxxxxx
22 xxxxxxx  xxxxxxx  xxxxxxx
23 xxxxxxx  xxxxxxx  xxxxxxx
24 xxxxxxx  xxxxxxx  xxxxxxx
25 xxxxxxx  xxxxxxx  xxxxxxx
26 xxxxxxx  xxxxxxx  xxxxxxx
27 xxxxxxx  xxxxxxx  xxxxxxx
28 xxxxxxx  xxxxxxx  xxxxxxx
29 xxxxxxx  xxxxxxx  xxxxxxx
31 xxxxxxx  xxxxxxx  xxxxxxx
32 xxxxxxx  xxxxxxx  xxxxxxx
There are just a few connectors left, if you need them now is the time to get them.
Offline McBryce
Ok, here's the editable version with all I have so far (plus your notes too).
I wouldn't be too worried about the availability of the connector, they are relatively easy to find:
ERNI - https://www.ebay.de/itm/96pol-Federleiste-Buchsenleiste-90-gewinkelt-3-reihig-female-ERNI-004516-/124355155637
Amphenol - https://www.ebay.de/itm/4x-Amphenol-Federleiste-Buchse-96-polig-90-C143-012B-96S-NOS/324247782999
McBryce.
« Last Edit: April 18, 2021, 01:03:10 pm by McBryce »
