Author Topic: Hewlett-Packard 1980B oscilloscope teardown  (Read 11102 times)
Offline tekfanTopic starter
  • Country: si
« on: April 30, 2011, 09:01:42 pm »
I think this oscilloscope deserves a thread of its own.
I got this scope a few days ago. It was broken like most of the equipment I buy. The HP1980 plays an important role in the development of analog and digital oscilloscopes.This is basically an analog scope with microprocessor control and waveform storage. It only has 100MHz bandwidth but it is extremely useful (like any oscilloscope).
The user interface is very unique as it uses soft buttons. You select the setting you want to change (time base, attenuation, trace brightness...) and then use the rotary dial to change the setting. The current setting is also displayed on the screen and on the LED display above the dial. The center module of the scope can be removed and replaced with either two more channels or a high resolution frequency counter. The CRT is also bigger than on a normal analog scope (6'' as instead of 5''). A unique feature is the AUTOSCOPE button. This is basically the same as the autoscale button on todays digital scopes.
The package you see here cost 16150 USD back in 1982. Today this would be a whopping 37,100 USD.
The scope already in cleaned state. Sadly I don't have the images to show you the before and after state.
Top of the scope with its sides removed. Z axis amplifier, HV oscillator, expansion PROMs, GPIB I/O (or in this case HPIB I/O), digital processor and control board and shield of the massive CRT.
Z axis amplifier at the top and the HV oscillator circuit at the bottom of the picture.
Digital processor and control board. The large metal thing at the back is a custom HP hybrid.
Lower board. Vertical and horizontal preamps, trigger amp, VCO time base, low voltage regulator, vertical and horizontal output amps.
Another hybrid for the vertical preamplifier, lots of HF compensation, gain and offset adjustments here.
Horizontal output amplifier. The output goes directly to the horizontal deflection plates of the CRT.
Vertical output amplifier. This connects to the vertical deflection plates of the CRT and the digital sampling board.
Vertical output amp hybrid. The gold contacts need cleaning, otherwise still in perfect condition.
Low voltage regulator circuit. Lots of opamps and 9 big bridge rectifiers (3 below the board) for the 9 secondary windings of the massive 300W mains transformer.
Hughe CRT!!! The deflection plates are gold plated. The anode voltage is 26KV.
This is the fan driver. Yes, this is what it took to drive a simple brushless fan 30 years ago.
The fan is probably the smallest and loudest fan I've ever heard. It's impossible to have peace with this scope turned on.
And no, the fan CAN'T be replaced since it's very small and very high RPM. There's just no more room in this thing.
This board is actually the digital sampler board used to store a waveform. Yes they had that 30 years ago.  A whopping 501 points of resolution (not megapoints, not even kilopoints).
The screen interface is very nice. Individual readouts can be turned on or off by just a touch of a button.
A real lightshow. I tried to make most of the softbuttons illuminate.
And yes this HP/Agilent draws 0 watts when turned off. But then again it draws 300W in normal operation.
Classic HP design with the extender shaft.
One can never have enough oscilloscopes.
Alex
  • Guest
Re: Hewlett-Packard 1980B oscilloscope teardown
« Reply #1 on: April 30, 2011, 10:08:03 pm »
And they wonder why engineers work in dark labs...to stare at the instruments ofc!
The custom ASICs remind me of that gadget from The man with the golden gun movie, 8 years before this scope was out. Now you know what inspired the movie. See at 5:12
James Bond 007 The Man with The Golden Gun Solar Energy. Roger Moore.
Great pics tek.
  • Country: si
« Reply #2 on: May 01, 2011, 12:23:31 am »
What a coincidence! The movie was just on TV yesterday.
You're right. Maybe the guys at HP were James Bond fans
Online EEVblog
« Reply #3 on: May 01, 2011, 06:33:57 am »
A thing of true beauty...
Dave.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #4 on: May 01, 2011, 08:31:28 am »
very nice front panel layout! 100MHz? that can be something! with all the discreet components inside. you did mention it was broken. mind to tell what was it and how to repair it?
Offline david77
« Reply #5 on: May 01, 2011, 09:36:38 am »
That is the most beautiful scope I have ever seen...thanks for sharing!
  • Country: si
« Reply #6 on: May 01, 2011, 12:11:23 pm »
100MHz is low because at the time scopes were basically judged by their bandwidth. Some Tek analog scopes already had 1GHz analog bandwidth.
Well, most of the softbuttons didn't work because if the contacts used to connect them to the pcb. The contacts are similar to the zebra strips used for LCDs. The hybrid ICs use the same principle. All the strips had to be cleaned. HV power supply was in serious need of cleaning because the dust gathered inside usually causes breakdown. Though the scope can be calibrated trough the front panel without removing the side panels, there are still quite a lot of trimpots and caps inside in need of calibration.
Offline Chet T16
  • Country: ie
    • Retro-Renault
« Reply #7 on: May 01, 2011, 12:21:36 pm »
^This. Theres something fantastically "retro futuristic" about it.
Great photos too
Chet
Paid Electron Wrestler
