I think marmad did a superb review as unlike many reviews, he briefly had all 3 scopes to compare by himself. You have to weigh things that are nontechnical too: which is easier to buy? Which seller is likely to give you an easy time returning it if it malfunctions? What if the Hantek dealer charges far less than the Owon, or the other way around? I prefer local vendors so I can return it easily, not one based outside the country. Amazon.com for example often pays for the return shipping too, but it varies by product and who is the actual seller.
Once hacked, it may not be returnable so keep it in mind, even if you reverse the hack; you could also brick it in the process.
Formally, when we buy large systems we put a checklist of needs or features, prioritize it on a scale from 1-10, and then look at the item to buy and score it based on how well it meets those needs; add it all up and whomever meets your score wins.
As BAW said, they all have pros and cons, which pros do you prefer? which con can you not live with? If you are looking for a general purpose scope and the pros and cons are unclear to you, then its probably clear either will do as you don't have a specific need that needs be met and can differentiate the strengths and weaknesses of either.
