Author Topic: Heated ultrasonic cleaners  (Read 1847 times)
Offline BudTopic starter
« on: November 17, 2016, 05:34:10 pm »
I wonder if having a heater helps in terms of speed and/or quality of ultrasonic cleaning. Would you recommend a heated unit vs plain vanilla one.
Offline LA7SJA
  • Country: no
  • Acting user manual reader & forum search engine
Re: Heated ultrasonic cleaners
« Reply #1 on: November 17, 2016, 09:16:53 pm »
I would recommend a heated, frequency sweeping unit (with a correct cleaning solution for the type of dirt). Read how Temperatures Changes Affect Ultrasonic Cleaning on this webpage:
http://www.zenith-ultrasonics.com/temperature_effects.htm
Johan-Fredrik
"If at first you don't succeed, skydiving is probably not for you"
Offline Fraser
« Reply #2 on: November 17, 2016, 09:33:14 pm »
My cleaning fluid from Allendale (UK) is designed for electronics use and recommends a temperature of 50C to 60C. When using an ultrasonic cleaner that does not have a heater you are recommended to heat the cleaning solution before pouring it into the cleaner or to use a heater that may be dropped into the fluid to heat it before using the cleaner.
Fraser
Offline David Hess
  • DavidH
« Reply #3 on: November 18, 2016, 07:24:50 am »
Heating makes a huge difference if only in that less time can be spent exposed to the rather harsh ultrasonic cleaning.
