Author Topic: Is it just me or are these DPMs almost nonexistent..?  (Read 1896 times)
Offline T3sl4co1lTopic starter
    • Seven Transistor Labs
« on: March 19, 2018, 07:31:31 pm »
Looking for digital panel meter, signed, 4 digits.
Metric shitloads of 3-digit LCD and LED meters.  Cheap from China or elsewhere.  A few bucks, no problem.
They're all 0-255 (well, 0-200 but who's counting?), 2V range, and I have a 0-5V signal to measure.  Ugh. I'd rather get an analog movement.
So it's got to be 3-1/2 or 4 digits, preferably the latter (or better).
Digikey has this:
https://www.digikey.com/product-detail/en/c-ton-industries/DK743/CDPM743-ND/278976
It's $50.  Let's say I want to spend $200 on DPMs, that only gets me four.  I want four right now, so that's okay.  But I'd rather have six or eight for projects in the immediate future, plus extras in inventory.
A tiresome perusal of Amazon doesn't show anything great from China.  None of them document the most basic things: what the display is (signed or not? half or full digit?), what the input connection is (common ground, or how much common mode range?) and so on.
This one is well documented, I have no problem designing it into a product, sight unseen.
Is it just me or is China actually slacking on a market niche here?
Or, alternately: is Amazon so badly searchable that, they're out there, and I can't find them?
Seven Transistor Labs, LLC
Offline BravoV
  • +++ ATH1
Re: Is it just me or are these DPMs almost nonexistent..?
« Reply #1 on: March 19, 2018, 07:40:00 pm »
Actually alot from China, if you don't mind the below standard documentation, at least better than none though.
Just one example sort by price  >:D out of so many of these 5 digits panel meter -> HERE
... and different colors too ..  :-DD
« Last Edit: March 19, 2018, 07:41:57 pm by BravoV »
Offline jimmc
« Reply #2 on: March 19, 2018, 08:45:09 pm »
I've used a couple of similar devices from ebay. Surprisingly accurate but only work for positive inputs.
Input resistance is around 300k.
Jim
« Reply #3 on: March 19, 2018, 08:45:59 pm »
Are those signed?  They don't look signed, and don't say so.
Ed: I see these look to be signed,
https://www.aliexpress.com/item/YB5145B-LED-Digital-DC-Voltmeter-4-1-2-Voltage-Meter-display-Tester-dc200mV-2V-20V-100V/32849928205.html
and even notes that the inputs are common ground.
There are about six other listings (in three stores?) for the same basic device, with varying ratings (poor translation).
The only other types in the listing are,
https://www.aliexpress.com/item/Four-and-a-Half-Digital-Voltmeters-Digital-Indicators-20V-200V-Four-wire-Precision-DC-DC-Voltmeter/32857126357.html
which seems to be pretty similar but shorter, and
https://www.aliexpress.com/item/High-accuracy-0-56-Red-LED-display-DC-voltage-meter-voltmeter-can-test-positive-and-negative/32319712361.html
this KETOTEK thing, which might well be the same.
Is this really it, in the world?
« Last Edit: March 19, 2018, 09:10:27 pm by T3sl4co1l »
Offline BravoV
  • +++ ATH1
« Reply #4 on: March 19, 2018, 08:49:54 pm »
Like this -> HERE ? , again, sort by price.  :P
« Last Edit: March 19, 2018, 08:51:38 pm by BravoV »
