Author Topic: Accelerometer Available in a DIP8 Package  (Read 9012 times)
Offline Stephen HillTopic starter
  • M3VXY
« on: April 01, 2012, 07:49:54 pm »
Hey,
I found this accelerometer in an easy to use 8 Pin DIP package. Enjoy ;)
http://uk.farnell.com/analog-devices/adxl206hdz/accelerometer-dual-axis-imems-8sbdip/dp/1903661
Cheers
Stephen
Re: Accelerometer Available in a DIP8 Package
« Reply #1 on: April 01, 2012, 07:52:32 pm »
Not exactly a cheap item though...............
  • M3VXY
« Reply #2 on: April 01, 2012, 07:57:19 pm »
Indeed.  ;D
Offline amyk
« Reply #3 on: April 02, 2012, 12:10:27 pm »
SBDIP is going to be expensive. This one also works up to 175C, not far from the melting point of solder!
Offline T4P
  • Country: sg
    • T4P
« Reply #5 on: April 02, 2012, 12:23:13 pm »
OOPS .  :)
What's the reason for most accelerometers being LGA packages , to prevent unintended flexing of the leads ?
Offline Psi
« Reply #6 on: April 02, 2012, 12:26:53 pm »
hehe.
"Well it went like this you see..  The IC was working fine right up until the point where the solder melted and it fell off the pcb"
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #7 on: April 02, 2012, 02:48:04 pm »
OOPS .  :)
I would think DIPs, especially plastic ones would be prone to unpredictable stresses during mounting and soldering, but the main reason is simply that nobody wants through-hole packages in volume.
Day Job: Mostly LEDs
alm
  • Guest
« Reply #8 on: April 02, 2012, 03:08:11 pm »
Except some niche applications requiring a temp range up to 175°C apparently. Did they ever develop extended temp (hermetically sealed ceramic) packages for SMT mounting? Probably not worth the cash investment given the sales volume. Getting the expansion coefficients of the board and IC close enough would probably also be a real issue at 175°C.
Offline Rufus
« Reply #9 on: April 02, 2012, 03:32:31 pm »
Plenty.
The funniest thing I have seen is ceramic/metal hermetically sealed versions of TO220 packages. The TO220 package being designed as a plastic replacement for the TO66 metal can package in the first place.
« Reply #10 on: April 02, 2012, 04:04:34 pm »
For fans of Mil package porn :
http://electricstuff.co.uk/milboards.html
Somewhere in my box of oddball parts, I have a ceramic DIP-8 which has a decoupling cap integrated on top of the package
Offline david77
« Reply #11 on: April 02, 2012, 05:23:38 pm »
Nice TO220 devices. Are they what I think they are? The MIL variant of the LM317?
Offline Monkeh
« Reply #12 on: April 02, 2012, 05:27:02 pm »
The LM117, actually. They're all from the same series. TO257 package.
« Reply #13 on: April 02, 2012, 07:12:47 pm »
Surface mounted ceramic packages were available years ago - flatpack units. I used to work with them, still have some around somewhere.
Offline T4P
  • Country: sg
    • T4P
« Reply #14 on: April 02, 2012, 08:43:59 pm »
OOPS .  :)
Indeed . Stress from hanging on leads and definitely nobody wants TH packages in volume , unlike most people on diystompboxes which think SMD is plain evil .
Offline baljemmett
« Reply #15 on: April 02, 2012, 08:55:57 pm »
Oh, now, that's one sexy VAX!  Or, well, parts thereof, I guess...
  • M3VXY
« Reply #16 on: April 02, 2012, 08:56:48 pm »
Someone is the related thread mentioned that these components would be so specialised that it's cheaper to buy the original component rather than designing and certifying a new component.
However, why would someone be buying these components from a distributor like Farnell. Wouldn't they buy them direct from the manufacturer?
