Author Topic: Hakko Nozzles vs 3rd party?  (Read 3141 times)
Offline TheBorgTopic starter
  • Hoping to start an EE degree soon...
« on: November 02, 2013, 01:31:58 am »
I bought a Hakko rework station a few days ago and am looking to get some tips for it. Nothing special at the moment, but I am seeing a lot of cheap nozzles on eBay where Hakko's nozzles can run from $20 to 300 dollars! Would I see much of a difference between hakko and 3rd party?
Youtube Channel - Assimilated Circuits
We are Borg. You will be assimilated. Resistance is futile.
Offline quarros
  • Country: hu
Re: Hakko Nozzles vs 3rd party?
« Reply #1 on: November 02, 2013, 12:26:52 pm »
...where Hakko's nozzles can run from $20 to 300 dollars!...
I think you meant max 30 USD  ;)
Anyways yeah Hakko tips are expensive but worth it. Once I tried a 3 party replacement tip with my 888 but the results where very unsatisfactory. It worked. But the solder did not flow on it so easily, and sometimes it did not stick to it as good as with the original, and it required much more constant maintenance (meaning: you had to be very thorough in cleaning it when turning the iron off, otherwise at the next start was troublesome). Can't really comment on longevity tough as I gave up on it after a few week's
« Last Edit: November 02, 2013, 12:28:43 pm by quarros »
Offline staxquad
  • Eye Candy
« Reply #2 on: November 02, 2013, 08:56:04 pm »
hot air
"TEPCO Fukushima you long time"
You say Vegemite, I say Yosemite. (Ve-gem-mit-tee, Yo-zey-might)
"For starters : you're Canadian...."
« Reply #3 on: November 02, 2013, 10:20:23 pm »
hot air
Thanks, yes, these are hot air nozzles. Apparently I have a thing where I'm not very clear when writing on forums  :blah:
Offline quarros
  • Country: hu
« Reply #4 on: November 02, 2013, 11:18:18 pm »
hot air
Sorry. Apparently misread.  :-[
My fault... Nozzle not Tip  :palm:
« Last Edit: November 02, 2013, 11:23:11 pm by quarros »
Offline ErikTheNorwegian
  • Country: no
  • Asberger, aspi, HIGH function, nerd...
« Reply #5 on: November 02, 2013, 11:38:13 pm »
I got these one just a week ago, very good.. and cheap... lots of money saved. Did fitt my BlackJack Solderwerks BK6000 (Aoye OEM ?)perfect..  :-+   The heads/plates have a mounting "tube" where they are attaced with a screw, simple- but it Works ok.
9 blowheads for 12 USDollar..
http://www.ebay.com/itm/Hot-Air-Gun-Soldering-Rework-Station-Nozzles-1-Set-Hakko-Aoyue-Atten-ZK105-/261303931969
Nozzles are compatible with Hakko, Kada, ATTEN and Xytronic, Aoyue 906, 968, 850, 6028, and many other systems
Direct replacement for Hakko Hot Air Rework Nozzles
All nozzles fit to  850/850A+ SMD Hot Air Rework Station.
Package :
9 blow head Sizes :
11.5 x 11.5mm
10 x 10mm
11 x 9mm
9 x 9mm
8.5 x 8.5mm
8.5 x 5.5mm
9.9 x 9.9mm
7.7 x 11.3mm
7 x 7mm
1 mounting (Inside Fitting diameter of 22mm.)
« Last Edit: November 03, 2013, 01:10:21 am by ErikTheNorwegian »
/Erik
Goooood karma is flowing..
Offline Shock
« Reply #6 on: November 03, 2013, 07:25:21 pm »
Yes they are cheap on eBay there is about 6 different clone nozzle packs from various sellers $1-2 each is the going rate in bulk.
I recommend you get a list from Hakko and go completely through eBay as what one guy sells for $100 another sells for $10.
