the fuse in my 888 blew and i had to unsolder and replace it
What did you replace it with?
The one I removed (NSF FCT from Nippon Seisen Cable) appears to be a
medium/semi time-lag. I can't find any readily available medium speed fuses, just quick/fast, but I'm not sure if the general speed ratings are that meaningful. Depending on the overcurrent range you look at some "fast" fuses are slower than this FCT "medium" fuse, though maybe not in higher currents.
630mA is in between so the extra step of the 500mA wire but not as common a fuse.
So that would make it more expensive rather than cheaper, no? If by chance they found some cheaper stock for 0.63A you wouldn't expect it to become the default type, as indicated on the fuse PCB. But for a 70W station 230V/0.63A is actually closer than 120V/2A, so maybe the 2A is the unexpected one.
BTW, any idea what's that small piece of rubber foam below the PCB for?
