Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Other Equipment & Products
Aluminium construction extrusion section????
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Aluminium construction extrusion section???? (Read 1067 times)
unknownparticle
Frequent Contributor
Country:
on:
January 31, 2020, 08:58:10 pm »
What is that square section aluminium extrusion section with slots for bolts etc, that is used to build jigs, benches, custom stands etc, called?
Logged
DC coupling is the devils work!!
Shock
Super Contributor
Country:
Re: Aluminium construction extrusion section????
Reply #1 on:
January 31, 2020, 09:13:26 pm »
https://www.makerstore.com.au/blog/t-slot-v-slot-profiles/
Logged
Multimeters: Fluke 189, 87V, 117, 112
>>> WANTED STUFF <<<
unknownparticle
aix
Regular Contributor
Country:
Reply #2 on:
January 31, 2020, 10:15:10 pm »
I know it as 2020/3030/4545/etc aluminium profile (the numbers are the cross-sectional dimensions in mm).
Logged
unknownparticle
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
Reply #3 on:
February 01, 2020, 07:31:03 am »
8020 is the brand name; IIRC, they sell at a flat price, which is fantastic if you need a fixture designed (they don't charge NRE, flat price is flat), but ludicrous if you just need a few pieces or are designing it yourself.
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
unknownparticle
beanflying
Super Contributor
Country:
Toys so very many Toys.
Reply #4 on:
February 01, 2020, 07:57:32 am »
In the UK depending on where you are you could try this mob
https://ooznest.co.uk/
They sell all the bits and custom cut extrusions.
Logged
unknownparticle
unknownparticle
Country:
Reply #5 on:
February 01, 2020, 02:34:14 pm »
thanks guys,
Logged
mjs
Regular Contributor
Country:
Reply #6 on:
February 03, 2020, 05:44:07 pm »
I've used Minitec, they've got design tool and the local reseller helps with designs and sends profiles cut to measure with all the other parts
https://www.minitec.de/en/products/profile-system
https://www.minitec.de/en/service/software
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
